Question about Refrigerators
Problem with our new refrigator
We found that it has 2 wheel and 2 leveling screws, but we don't have any idea how can we lock the wheels. We have stone an kitchen's floor and the refrigator could move without real lock. Is it possible to lock the wheels?
  • ubedos Apr 29, 2009
    Honestly I have looked everywhere and I have no idea on how to lock these wheels...
  • 552 Answers
Try www.castercity.com
They amy have what you are looking for if you tell them what brand you have.
Posted on Feb 20, 2008
I have a Delta 6 bench grinder model #23-680. How do I hold the shaft from turning as I loosen the nut hold the grinding wheel in place?
Hold (or lock) the grinding wheel on the other side if loose or lock because the locking direction is the same direction and don,t forget to ringing (sound-check -like a tuning fork) the stone if you replace it with a new one The risk is small but safety first
Apr 10, 2017 | Delta Grinders
I want to move my fridge but it's locked in place. How to unlock?
Hello Tina;
My name is Peter. I am a retired field service refrigeration technician.
You did not post your model number which is located on a label on the inside liner wall of your fresh food section.
First remove the bottom grill or toe plate in front of your refrigerator. This plastic piece is either held on with one screw at each end or pop out clips. If clips pull the plate straight out about 2" from each end. This plate is easier to remove with both doors open.
Refrigerator Leveling Screws: Most refrigerators have two leveling screws in the front, one on each side. These screws are for leveling the refrigerator from rolling on the wheels. Turn these screws counter clockwise.
Refrigerator Wheel Locks: Some refrigerators have a lever bar on the outside of the front wheels to lock the wheels in place.
Refrigerator Independent Wheel adjustment Screws: Some refrigerators have two hex head screws on each side. They raise and lower both the front and back wheels.
Mar 04, 2016 | Refrigerators
How do you lock the wheels on a maytag refrigerator
Hello Joyce;
My name is Peter. I am a retired field service technician.
You did not give me a model number so I am not sure what you have.
Remove the front bottom grill. Some grills have clips 1 on each end that you just pull to remove. Others have a screw on each end to remove.
1.) Some units have a locking bar on the outside of the front wheels. Turn this bar to lock.
2.) Some units have bars on each side with square heads. There are 2 bars on each side. One for the front wheel and one for the back wheel. You need a box wrench or ratchet. Clockwise raises the wheels and counter clockwise lowers the wheels.
3.) All units have leveling screws in the front. Turn the jack screws clockwise to bring them down. If you did not receive a special wrench with the unit, you will need either a pair of channel locks or another tool when the jack screws touch the floor. Turn the jack bolts 1/2 to 1 full turn. This will secure the refrigerator in your desired position.
I do not recommend 3.) unless your floor is pitched and your refrigerator tends to move. The leveling jack may leave impressions in you kitchen floor. Generally, just the heavy physical weight of your unit keeps the refrigerator in place.
Oct 29, 2014 | Refrigerators
Can the front wheels be locked
I just Fixed this problem today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel.
In 3 business days a received, a brand new front wheel with pedals and fork. The pedals are fixed on wheel, and is the best solution from radio Flyer for a Kid who is grown with the bike from 18 months to 36 month, and now at age 3 rides the lovely Radio Flyer like a dare devil. Thank you Radio Flyer.
Having a strong mechanical background, I opened system, both sides of the wheel. To dissemble and repair, I had to remove one pedal on the side of the big white hub. What I found inside was a Ratchet wheel, with rounded teeth, and 2 Pawls totally worn out.
I fixed drilling 4 holes all the way through metallic plate, ratchet wheel, and the hub of the wheel. Inside the hub cavity, I used 4 washers and nuts to secure tight all 4, 3/32 stainless steel screws.
My grandson is very happy and more confident, because now he can move the bike forward, and backwards, and the most important, now he can use the pedals of the front wheel to stop the bike. Which it was a safety flaw by original design of this bike, but solved now by Radio Flyer. The new wheel Red Hub has 2 Positions. 1 PULL TO COAST. 2 PUSH TO PEDAL.
Jul 22, 2014 | Radio Flyer Steer and Stroll Deluxe Trike
Leveller
Check the wheels as they may either turn to go up and down or there may be a screw that does this adjustment. Place a level on top of unit. Get one direction level then do the other. May only have to adjust one wheel/leg to get unit level.
Apr 22, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Have to push the pedal to the floor to get car to stop. Fluid levels fine.
If the pedal really is going down to the floor you must have air in the system and you are compressing it. It is possible to get a very minor leak that lets air in but very little fluid out. If the pedal is going down to the usual level your servo could be acting up. If you get somebody to run the engine and then stop it and press the brake pedal while you listen under the bonnet you should be able to hear the air rush in when the atmospheric valve opens. If it doesn't you may have a leaking hose or the atmospheric valve is not working properly.
Another possibility is seized pistons in your calipers or they are rusted up and sticking. If you jack the car up and get someone to press the brake pedal and see if it locks each wheel in turn, when they take their foot off the pedal you should be able to turn the wheel by hand. If the wheels don't lock when the foot brake is applied or don't unlock when the pedal is released the problem is probably either sticking disc pads or seized pistons.
Jun 09, 2012 | 1994 Honda Civic
Replacing cord on polaris 250 ATV ??
CORD? THE ONE TO START THE ENGINE.
Park the Polaris ATV on level ground in an area with plenty of light. Allow the engine to cool if it is warm so that you don't burn yourself.Remove the four Phillips head screws from the corners of the metal cover that the cord is coming out of using the screwdriver. Pull the metal cover off the engine. Unwrap the cord from around the turn wheel completely.Spin the turn wheel using your hand until the nut securing the cord is at the top of the wheel facing you. Grab the metal stem on the cord with the pliers. Loosen and remove the nut using the box wrench. Hold the stem to keep the cord from turning as you loosen the nut.Pull the cord off the turn wheel and through the hole on the metal cover. Keep the nut just in case the new cord did not come with one. Insert the metal stem on the new cord into the hole on the metal cover. Insert the stem into the hole on the turn wheel.Tighten the nut onto the stem the opposite way than you removed it. Spin the turn wheel counterclockwise until you hear the spring lock into place. Wrap the new cord around the turn wheel. Make sure that the cord does not overlap itself. Replace the metal cover to the engine. Replace and tighten the screws to secure the cover to your Polaris's engine.
  • Dec 04, 2011 | Garden
    I downloaded the manual for this unit and it says to adjust the front leveling wheels to bring it to level. I removed the grill and looked for the adjustment screw...there is none. shimming is not an...
    Front wheels should screw in and out for adjustment purposes!!!!!!!!!!!! And with that degree of tilt you might just have to resort to shimming so be ready.
    Aug 27, 2017 | Amana ATB1932MR Top Freezer Refrigerator
    I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
    I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
    Jul 15, 2011 | Dremel Garden
    Refrigerators Logo
    613 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
