Question about Electric TPI CORP TBS BASEBOARD HEATER THERMOSTAT
Heater core needs to be replaced just need to know how to remove and install a new one first car ever had its a 97 dodge intrepid pple have told me it starts with takeing the dashboard apart is this true? please some give me a step by step instructions thanks you very much
  • 13 Answers
You should be able to get instructions when you buy the heater core ask the store to print you out a copy most stores will be glad to print the instructions for you. you dont have to really ask for instructions you just have to have a day aside for taking bolts out until you get to it. it will take some one more then 10 hours to do it but you will safe lots of money.... once you start you will see your self were you need to go next that is how i have fixed all my car problems...
Posted on Feb 06, 2010
How do I replace the turn signal assembly on a 97 Chrysler LHS?
Carmon, check the posted links to see how to replace the turn signal switch. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Install Replace Turn Signal Wiper Switch Dodge Intrepid 93 97...
How to Replace Turn Signal Switch Chrysler Sebring
97 dodge intrepid turn signal problems
May 31, 2016 | Chrysler Cars & Trucks
My grandma asked me and I have no clue about cars so I'm a ask for help who knows a lot about a 1997 dodge intrepid? she says friend of hers told her that her rack pinion needs to be replaced eventually...
What is the problem that she is having with the car? IF the rack and pinion was bad, there would be steering issues. IF the heater core was plugged there would be no warm air in the cabin of the car..
Dec 22, 2014 | 1997 Dodge Intrepid
How do I flush water out and add antifreeze to my 2001 dodge intrepid
Technically speaking, the cooling system uses a 50-50 mix of coolant and water. You can buy coolant already mixed, or full strength.
There are hydrometers that you can buy to test the condition of the coolant. I would suggest draining the radiator and refilling with full strength, then test it. You would still have some water in the block and heater core to mix with the new coolant.
Jun 08, 2013 | 2001 Dodge Intrepid
Need to change out my heater core 2003 dodge ram 1500 I have the problem with the heater blowing hot on the passenger cold on the driver's side and now my heater does not work at all I believe the core is...
If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
  • The heater housing is usually under the dash and must be removed to gain access to the heater core.
  • Procedures for replacing the heater core vary with the year, make, and model of car. It threfore necessary to consult the manufacturer's repair manuals for the proper procedure for replacement.
f74-01.gif The heater housing is disassembled to get to the heater core. Heater Core
  • Remove the access panels(s) or the split heater/air conditioning case to gain acess to the heater core.
  • Remove the heater coolant hoses.
  • Remove the cable and/or vacuum control lines (if equipped).
  • Remove the heater core securing brackets and/or clamps.
  • Lift the core from the case. Do not use force. Take care not to damage the fins of the heater core when removing.
  • To reinstall the heater core, reverse the removal steps.
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
Jan 05, 2011 | 2003 Dodge Ram Maxi
I replaced heater core on 97 ford f150 need map on how everthing goes back together
Heater Housing
Dec 21, 2010 | 1997 Ford F150 Regular Cab
I have a hole in my gas line up by where it goes into the injectors in my 97 intrepid.how and what do i need to do to repair or replace it?
YOU NEED TO REPLACE THE FUEL LINE.YOU NEED TO RELIEF FUEL PRESSURE FIRST.BUT THE LEAK WILL BLEED OFF FUEL PRESSURE.ALL YOU HAVE TO DISCONNECT REMOVE THE LEAKING FUEL LINE AND INSTALL THE NEW FUEL LINE.
Nov 27, 2010 | 1997 Dodge Intrepid
97 dodge dakota. Tried to replace the heater
There is some wire shorted to ground during the dash work due to some pinched points. Need to revisit the re-installation work.
Dec 12, 2009 | Dodge Dakota Cars & Trucks
I need to know what size bolt is on the harmonic balancer of a 97 intrepid
Those bolts are specialized, non-reusable bolts. Any time you remove one, you must get a new one to replace it. Size is Irrelevent; as you should refer to a parts store to get one based on application
Oct 16, 2009 | 1997 Dodge Intrepid
Wiring for the 97 Intrepid radio
Do yourself a big favor & buy the adapter plug for the harness, that converts your Chrysler harness to easy install of aftermarket stereo. Any autoparts or audio store should have them.
Jun 04, 2009 | 1997 Dodge Intrepid
Heater core going out on my 97 dodge ram 1500
the dash has to come out so you can get to the heater box.
Jan 21, 2009 | 1997 Dodge Ram
Electric TPI CORP TBS BASEBOARD HEATER THERMOSTAT Logo
112 people viewed this question
Top Electric Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Electric Measuring Tool and Sensor Expert? Answer questions, earn points and help others
