Question about Dell Inspiron 1000 Notebook
My insperon 1000 gets hot then slows down till it freezes. During diagnostics its giving a error message code 0F 00 131B
    President:
  • 1,185 Answers
Are the cooling fans underneath running up to speed
If not the processor will get very warm and shut down
Get a can of compressed air from Radio Shack and blast them clean
Posted on Feb 04, 2010
What does it mean when my 2008 trailblazer LT stabilitrac service light comes on?
Service Stability System Message The message center displays the service stability system message when any one of many VSES-disabling DTCs is set. The EBCM sends a serial data message to the IPC requesting this display.
It means there is a problem an till you get it fixed the stability control system is disabled ! ( EBCM ) electronic brake control module Has detected a problem an set a DTC - diagnostic trouble code in it's memory an had the message displayed !
Vehicle Stability Enhancement System (VSES)
The vehicle stability enhancement system (VSES) provides added stability during aggressive maneuvers. Yaw rate is the rate of rotation about the vehicle's vertical axis. The VSES is activated when the electronic brake control module (EBCM) determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated by the EBCM using, primarily, the following inputs.
The position of the steering wheel
The speed of the vehicle
The lateral, or sideways acceleration of the vehicle
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. When a yaw rate error is detected, the EBCM attempts to correct the vehicle's yaw motion by applying brake pressure to one or more of the wheels. The amount of brake pressure which is applied varies, depending on the correction required. The engine torque may be reduced also, if it is necessary to slow the vehicle while maintaining stability.
VSES activations generally occur in turns during aggressive driving. When braking during VSES activation, the pedal may pulsate. The brake pedal pulsates at a higher frequency during VSES activation than during ABS activation.
It
Jun 19, 2015 | 2008 Chevrolet Trailblazer
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
Mar 20, 2015 | Kitchen Appliances - Others
Error message 2000-0151 on dell inspirion 1545
Hi.
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
Error 0333
The Diagnostics runs tests that need to have user interaction, Error codes below are because of no user interaction:
  • 1000-0312
  • 2000-0333
Re-run the Diagnostics while being at the Computer to interact with the Diagnostics.
or
Remove and reinstall the Video Card on a Desktop Computer for error codes:
  • 1000-0332
  • 2000-0332
  • 1000-0333
  • 2000-0333
  • 1000-0334
  • 2000-0334
so, please type more detail to be more exactly
Jan 09, 2011 | Dell Inspiron 1501 Notebook
While running diagnostics am getting an error code 2000- 0111 in my inspiron 15R laptop
If you receive an error during PSA Diagnostics, look below for the associating error code. If the Error
Error Code
Error Message
Link to Possible Fix
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
Contact Dell
Jan 04, 2011 | Dell Inspiron 1525 Notebook
What can i do to stop freezing in nokia 2626. if i power on my nokia 2626, the phone hangs after some seconds and i don't know what to do
Nokia models starting with 2 series are generally very slow. Once it is started it will be back to normal. It will take about 3 minutes to start up. Please wait during that period. Once it is started you can use everything except messaging, which will take another 10 more minutes to get ready. Till then it will show the message "Message storage memory not ready".
Jul 05, 2010 | Nokia 2626 Mobile Phone
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Jul 16, 2009 | Rheem Tankless Hot Water Heater...
Insperon 1501 freezes
This can be caused by hardware or software. Eliminate the hardware by running a diagnostic check. To do this, hold down the <FN> key and push the power button. If hardware checks out, you probably have a software, virius or spyware issue.
Oct 15, 2008 | Dell Inspiron 1501 Notebook
Microsoft LifeCam VX-1000 Freezes with Skype
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Jan 23, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Dell Inspiron 1000 Notebook Logo
203 people viewed this question
Alun Cox
