Question about Hitachi UT42V702 42 in. LCD TV
My super slim 42 inch hitachi tv does not respond
My slim 42 inch hitachi tv does not respond - screen remains black and cannot reach áV1 or AV2 or even HDMI1 or HDMI2. Just black, I tried to switch off everything, the control box, the tv, nothing changes. Only accessible 'options' which are prompted in the right corner of the screen are RGB and HDMI, but screen remains black with apparently no sync signal... I know that the HDMI cable works fine, tv is plugged correctly, box as well.
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
  • 1153 Answers
SOURCE: Re: Hitachi TV Model 42EDT41 42 Inch
panel defect
Posted on Dec 26, 2007
SOURCE: RCA flat panel L42FHD37 When first
You can easily fix this audio problem by downloading a software upgrade for your HDTV. And you don't have to be a rocket scientist or a brain surgeon either ;)
If you need to find the software upgrade:
Go to RCA.com and click on Support, from there you will click technical support. In technical support, click on the link called Software Download. Scroll to the bottom of the page where you will find 2 links. The first link will tell you how to download the software to a Mini Cruzer USB drive (you need at least 15MB of space) and the second link is the software download itself.
Posted on Dec 10, 2008
SOURCE: No hdmi signal
hold down your playstation button for a few moments and it will automatically sync to the tv at optimal settings. And thatz wut it doobi
Posted on Dec 31, 2009
SOURCE: I get the following error code when I press the
I changed out a HDMI to HDMI cable for a DVI-I to HDMI cable.
Posted on Jan 22, 2010
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42" TV
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Jun 19, 2008 | Hitachi 43FDX01B TV
Picture problem on certain stations
I seen this problem. On my tv the text caption was on. Check your caption mode, turn off see if problem goes away.
Jul 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42HDT50 42 inch
You can download the manual from Hitachi here:
http://www.hitachionlinestore.com/manuals/32_42_50HDT50.pdf
All should be covered there.
Mar 16, 2007 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Hitachi UT42V702 42 in. LCD TV Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
