Question about E-Machines (308714) Motherboard
When i press the on button the fans run, but no booting
When i press the on button the fans run, but the screen does not display.
i have tried re-seating RAM, changing the processor.
i also tested the RAm and processor in another machine and they worked.
i need help, the computer is a fujitsu Siemens desktop
thanks
  • 596 Answers
Have you tried a new power supply. Sometimes the ps will go bad and not supply the correct voltage needed to power your entire system. My experience with emachines have come to this conclusion about 98 percent of the time.
Good Luck
C2Solutions
Posted on Feb 04, 2010
Toshiba L455
If this were a backlight problem, you probably wouldn't be able to see the Toshiba Splash Screen.
Do you see a little dash at the top of the screen? It sounds like your hard drive has lost its MBR (master boot record) or completely failed. The MBR tells the system where to find the operating system on the drive. Try finding a Windows OS install or upgrade disc or your Recovery disc. (For a Windows CD, you'll want to match your current OS.) Alternatively, find a LiveCD of a drive partitioning program (with a repair MBR feature). I've used the True Image and Paragon Partition Manager.
Try to boot from the optical drive. (You may need to access the BIOS to change the boot disc; press F2 after powering up the computer. If you get to the blank screen, then shut down and retry. It takes me several attempts to get into the BIOS.) If you can get the boot CD to work, try to repair the computer. Let me know if you need the details. It will depend on if you are using Windows media or a Partition repair Live CD.
You can also try to restore from your backup. (I hope you back up regularly.)
I hope this helps.
Jun 29, 2013 | Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
No display after reboot windows
If it seems like your system is running whereas you hear fans running, hear the hard drive running, see lights, heard the hard drive click during bootup, but there is nothing on the lcd screen then try the following:
1) Try hooking a external monitor to your laptop. It can be any type of monitor even one of the old style fat crt monitors as long as it has a vga cable to connect to the laptop. There is a sequence of keys you might have to hit to get the display to show on the external. Most times you hit the FN (Function key) and hold it while you hit the corresponding F1 thru F12 key that is for display. Usually the correct key will say CRT/LCD or it might have a display icon on it. If the image displays on the external monitor that means the video card is good.
2). Remove the external monitor and reboot the computer again. Now when it is done booting take a flashlight an shine it on the lcd screen. You are looking to see if you can faintly see the icons on the screen. If they are there but barely visible then the LCD Inverter is bad. The LCD Inverter is located at the bottom of the lcd screen just above the keyboard and the Strip around the lcd screen covers it. You'll have to take the lcd apart to get to it.
3) If you don't see anything when you shine a flashlight on the desktop, then the lcd screen has to be replaced. However, sometimes the cable on the back of the lcd screen has come aloose or just needs reseating, so unplug the cable and put it back then see if it shows an image.
Read Below if it is not booting at all when you press the power button.
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 23, 2012 | Computers & Internet
How to solve problem after reboot my notebook dell no displaY
Mar 23, 2012 | ASUS Eee Computers & Internet
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
I have a new Carrier HVAC system with a fancy EDGE thermostat. When I turn the system OFF at the thermostat, and set the fan to AUTO, hours later I will find that the fan is running and it's setting on the...
1. Open the door. 2. Press and hold the buttons underneath the heat and cool setpoints simultaneously (the two bottom buttons on the right) until the screen displays the reset reminders and 01 in the lower right corner. 3. Press the up arrow button until 01 changes to 07 with OF (fan mode) next to it. 4. To turn the fan on, press the rightmost lower button then press the up arrow button until the screen displays ON. To turn the fan off, press the rightmost lower button then press the down arrow button until the screen displays OF (off). 5. Press the done button. 6. Close the door.
Jun 06, 2010 | Carrier 36KCARMS Air Conditioner
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
E-Machines (308714) Motherboard Logo
161 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
