The unit is freezing up. i have an outside unit and i'm trying to pull heat.
  • 334 Answers
That indicates one of three things.
1) Lack of airflow
2) Improper refrigerant charge
3) defrost malfunction
1) Make sure the outdoor coil is clean, and the fan is operating properly at the right speed.
2) IF you are certified, check the refrigerant level.
3) If the unit simply will not go into defrost at all, then the sensor or the defrost board is bad. If it goes into defrost too infrequently, the timing should be adjusted. If it goers into defrost repeatedly and quite often, and the ice build up is simply more than the defrost cycle can handle, look to problems 1 and 2.
Posted on Feb 06, 2010
How do you clean the filters on the outside unit of split system Mitsubishi reverse cycle 18RV
Outside unit does not have a filter. You can try to pull the disconnect on the outdoor unit. Reinsert after 10 seconds, see what happens.
Jul 08, 2017 | Mitsubishi Heating & Cooling
Outside unit freezing up and not heating up room inside
Check the defrost board in the outdoor unit... it should have a wire coming off pins that are stamped 30, 60, or 90. If the wire is on 90, then try setting it to 60 or 30. This just enables the defrost board to check the freezestat in minutes...the shorter amount of time, the less likely the unit will freeze up.
Dec 16, 2013 | Soleus Ductless Mini Split 9000 A/c...
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Outside conndenenser does not tun off
Sounds like a welded shut contactor coil. The contactor coil will have to be replaced so the unit turns off by signal from thermostat. Conatctor coils are about 30 dollars and be purchased at any heating and cooling supply store.
May 03, 2012 | Heating & Cooling
Mod# PTH093A35AC: Unit has quit running. Blower appears to be frozen up. Prior to non-functioning it was making a loud clicking sound while running in heat mode, almost like coils were freezing up....
yes the blower can be replaced / not all that difficult have a screw gun ready though...several screws to gain access.... the unit normally comes as a sealed system (meaning no actually service ports to add freon but can be ported and a tap added to check and add refrigerant to system... these heat pump systems are great when working correctly ,but when it does drop below 20-25 degrees outside they will start to freeze as the defrost cycles in them are normally not very long and the unit cant keep up so in return they will start to freeze up, however if the blower motor started to go out and unit was running it will freeze up on you.... hope this info helps out feel free to repost with anymore questions you may have.....
Feb 11, 2011 | Amana PTH09 Air Conditioner
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Outside unit freezes up
the unit must be in heating...
when we heat the room we effectively refrigerate outside to gain heat and put it to the indoor unit, hence the outdoor coil freezes up, it should defrost every now and then but each unit is individual..
check your settings
cheers
Jul 03, 2010 | Heating & Cooling
Why the out side unit get ice and freezing when it work on heat
this is common your condenser becomes the evap. pulling heat from outside air to heat your home.assuming were talking about a heat pump
Feb 13, 2010 | Samsung AS18A6RB Air Conditioner
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
