I have A KLH S200ETH with no sound. Burnt resistors
I have A KLH S200ETH with no sound.Upon amp removal, 2 ) resistors were found burnt. Ineed a schematic 4 unit. Please any help?
  • 547 Answers
SOURCE: i burned up some resistors
This is a pretty common problem with this sub.
Here's a solution that I posted earlier this year, including schematics for the upper and lower circuit boards. Be sure to check the circuit board revisions to make sure they match my schematics.
Posted on Sep 06, 2010
  • 631 Answers
SOURCE: Rockford Fosgate 200S amp, not powering up, some burnt components found.
If the resistors go to the gates of the power supply FETs, the FETs are probably shorted. Measure the resistance between the gate and the drain (no power applied to the amp). It should be at least several thousand ohms.
If you can take high res photos, send them to my email address:
babin_perry@yahoo.com
Posted on Dec 21, 2007
SOURCE: KLH ASW10-120B subwoofer
Hello, I have the same unit and even though I havn't had any problems with it, i do have the instruction booklet plus some other "techie" type material that may help. My friends an engineer and had some I am completley new to this site and don't know how to get ahold of people directly
Posted on Feb 04, 2008
tantong
  • 138 Answers
SOURCE: burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Posted on Mar 16, 2008
SOURCE: Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Posted on Mar 14, 2009
Circuit diagram of the power supply section of KLH S200ETH, anyone?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given
Oct 23, 2016 | Televison & Video
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
Yahoo.comThe a/c switch does not work in any position. 1st 1 & 2 went, then 3, then 4 and finally today 5 went out
1-2-3 WHENT WHEN RESISTOR BURNT OUT
4 ON A RELAY COULD ALSO BE BURNT
5 ALSO ON RELAY THAT COULD ALSO BE BURNT
I ASSUMED THAT THE HEATER FUSE IS OK (CHECH PLEASE)
IF ALL OF THIS IS BURNING UP THE BLOWER MOTOR COULD BE FAULTY
OR THE SPEED SWITCH COULD BE THE CAUSE
LOAD TEST THE MOTOR ON IT'S OWN TO SEE IF OVERDRAWS EXIST
IF NOT CHECK OR REPLACE THE SWITCH
THE RESISTOR ARE KNOWN TO GO
BUT USUALLY THE RELAYS ARE GOOD AND STRONG
THE RESISTOR WOULD BE CLOSE TO BLOWER MOTOR
AND MOST RELAYS ON TOP OF AIR DUCK BEHIND GLOVE BOX
GOOD LUCK
May 26, 2011 | 1998 Chevrolet Malibu
All resistors are burnt ineed the part numbers for Pvy .model 2600
Send me your email with subject Peavey and I will send PDF of schematics, etc.
Aug 11, 2010 | Peavey PVĀ® 900 360W Power Amplifier
I burned up some resistors in my klh asw120 # r52 r48 and r49 i need the values to them so i can replace them they are too burnt to tell the color code please get back to me with the values! Thanks JASON
Aug 10, 2010 | KLH ASW10-120 Subwoofer
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
2005 Dodge Caravan front fan is not working in any speeeds. The rear fan is working just fine. Opened the glove compartment and it does smell burnt. Is this just the resistor or is it the blower motor?
The resistor is relatively in expensive and easy to change...I recently had to change it in my 06 pacifica, upon doing research, I found the resistor to be a common problem in several dodge/chrysler models from these few years. Most stores wanted $80+ for the resistor, Autozone was $12.xx. It is very unlikely that blower motors go bad.
Dec 02, 2009 | Dodge Caravan Cars & Trucks
Dec 21, 2007 | Car Audio & Video
607 people viewed this question
 Grubhead
Grubhead
