Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Their is a cable that attaches to my dlp bulp that was removed, im not sure what that cable is and where to get it
  • 111 Answers
The cable is for the lamp take the one off the old lamp
Posted on Feb 04, 2010
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
I got on my projector screen plenty white spots started with 5 now they are closed to 100 do I need to change the bulp it has lees then 500hours?
I think that the problem of your unit is the lens of the bulb is dusty. Unplug the unit and let rest for at least two hours. Then locate the lamp unit door on the side of your dlp it is labeled, open the door and remove the screw that secure the lamp. Be very careful to remove the lamp from its housing and clean the lens with microfiber cloth. Note be sure not to touch the lens. Hope this help good day and best regards.
Sep 02, 2011 | Televison & Video
I have an rca hdlp6iw51 and i found a color wheel on ebay but i dont know how to change it does anyone have any advice
Follow this steps:
1. Take the back panel off of your set, using your Phillips head screwdriver, to remove any screws. 2. Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further. 3. Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
4. Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 3 Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further.
  • 4 Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
  • 5 Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 6 Pull out the entire center unit, pulling gradually. Then, unplug the power cable from the main set (this is generally blue and brown). Remove the sensor switch and any cables joining the center unit to either side of the set.
  • 7 Take out the plug from the cover of the color wheel. In most brands, it will have a black and blue wire connected to a green circuit board. Then, remove any cables coming out of the wheel. Depending on the brand, the screws may be small enough to require the jeweler's screwdriver.
  • 8 Remove the screws holding the color wheel cover in place. Remove the cover, then take out the screws holding the wheel in place. If tape is holding the wheel, just pull on the wheel until it comes free.
  • 9 Put the new wheel into the slot. You do not want to touch the wheel, or you will blemish it and leave impressions that will be visible when the light shines through it. Re-insert the screws. Then, replace the cover, making sure that the wire jacks are in the same places.
  • 10 Reassemble the DLP television, then plug the set into the wall, and turn on the power.
  • Read more: How to Change a DLP Color Wheel ' eHow.com http://www.ehow.com/how_7697815_change-dlp-color-wheel.html#ixzz1VdDl2OQb
    Aug 21, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
    I have a HLP56633W and have changed both the color wheel and the bulp and I have no picture, any ideas?
    About the only things left are the Ballast and Power Supply Board.Samsung recommends replacing both at same time.
    Jun 15, 2010 | Samsung DLP HL-P5663W 56" TV
    Samsung DLP R&R Color wheel Model #HLR5078w
    Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
    Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
    Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
    Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
    Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
    5
    Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
    6
    Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
    7
    Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
    8
    Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
    May 02, 2010 | Samsung HLR5064W DLP Projection TV
    My dlp tv keeps switching itself off
    take bulp vent cover off rear of tv. there is a little plastic switch that gets pressed in by this cover. i taped mine in because the cover wasnt pressing it in all the way and causing tv to shut off all the time. havent had a problem since.
    Jan 11, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
    How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
    5
    6
    7
    8
    Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
    Color wheel for Samsung HLR5688WX DLP TV
    5
    6
    7
    8
    Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
    The Dlp bulb
    The bulb may be defective or it may be the ballast. The bulp is alot cheaper, try replacing the bulb first.
    Aug 30, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
    Panasonic Model # PT52DL52 52 " HDTV DLP (2003). Working fine and all of a sudden heard a pop and TV quit. It's not the bulb since fairly new and the bulp idiot light is not on. I think it may be...
    Remove the lamp and look into the left side of that compartment to see if you can find glass/color wheel bits and pieces. I just recently had this happen and when I turn on the tv the red power on indicator blinks twice. Check to see if you have power to the tv
    Aug 25, 2008 | Televison & Video
    Mitsubishi WD-62525 62" Rear Projection HDTV Logo
    32 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
