Question about JBL SCS145.5 System
Foreign matter in my subwoofer
My daughter dropped block(s) into my husband's JBL Sub160 subwoofer. How do I/can I get them out?
So far, I have counted almost 30 screws (3 different sizes) and one big bolt - I don't want to demolish the functioning subwoofer in trying to get a toy or two out of it.
There are four Phillips head screws on the bottom of the sub woofer. Carefully remove these screws being certain not to puncture the speaker. The speaker should be easily pried from the hole by using one of the holes around the perimeter of the speaker, be careful not to puncture the speaker. There are two wires attached to the speaker, they can only be replaced on the terminals they came off of as they are different sizes. Carefully pull these wires from the speaker and retrieve the blocks. Re assemble in the reverse order you took the unit apart. Hope this helps.
Posted on Dec 10, 2008
    Sergeant:
  • 261 Answers
Can u pick it up and shake it or keep turning it on its sides until all blocks come out. :-) Gravity can do many good and bad things. Perspective is everything. Good luck... GURU JAY
Posted on Feb 20, 2008
JBL PRX515/230
Hello
Check its power supply section. Voltage/s are missing.
Feb 29, 2012 | JBL PRX515 Speaker
My jbl cvsub50 blows a fuse instantly when turned on. I am assuming the amp is blown. anyone help?
Yes this generally means a major problem - main transformer or output transistor(s) likely.
One year factory warranty on the electronics.
To find the authorized JBL service center in your area:
  • Go to: www.jbl.com
  • Click on United States
  • Click on Support at the top
  • Click on Find My Product
  • Enter your Model Number or Select your Product from the drop down list; then SUBMIT or SEARCH
  • On the list on the left side, click on Service Center
  • Supply your zip code at the next screen, then FIND
  • A list of service centers in your area will come up.
Nov 21, 2010 | JBL CinemaVision CVSUB50 Subwoofer
The subwoofer stops working and makes a loud flat sound that can only be stopped by unplugging it. I replaced the subwoofer with another one in the house so it's not a receiver or wire connection...
One year waranty period from JBL on the electronics.
Nov 17, 2010 | JBL SCS135 System
JBL PB10 has lost power even though still plugged into wall, any suggestions?
Do you mean like the subs power lights dimming when playing it at volumes it once had no problem playing, or loss in sound, distortion?
Oct 10, 2009 | JBL PB10 Subwoofer
No sound out of JBL LSR25P speakers attached to keyboard
problem could be in wiring, fuse, crossover or the components can be damaged. the original JBL tweeter and 5.25" speaker are no longer available so replacement options would be the only alternative.
cathy@speakerex.com
Jun 13, 2009 | JBL LSR25P Speaker
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Apr 10, 2009 | JBL PSW-D112 Speaker
Creda IWD12 filter.
As far as I remember it goes like this.
take the filter in your hand and turn the knob counter clock wise intill it almost comes off. Then gently shuff it into the filter hole. Push it in as far as you can and than tighten it again.
Maybe the following link will help you
CREDA IWD12
Apr 20, 2008 | Creda IWD12 Front Load Washer / Dryer
Thump at the time of shutoff
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Mar 07, 2008 | JBL PB10 Subwoofer
JBL W15GTi repair?
you probably blow them out. i doesnt really matter if you never powered them up to the max, try a different speaker and see if they work, doesnt really matter what kind of speaker.
Nov 30, 2007 | Car Audio & Video
JBL SCS145.5 System Logo
197 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
