Question about Jenn-Air JGD8130 Gas Cooktop
Gas Range Oven Knob Area Gas Leak
We have an older mid 80's Whirlpool Gas Range. We suspected a gas leak and had the gas company out to confirm that there is a gas leak around the oven knob only. The four burner knobs did not set off the gas detecter wand when set next to them like it did for the oven knob. So I was wandering if there is a relatively easy inexpensive solution to stop the leak. I have not yet tried to open up the top of the stove to look at any of the mechanisms. Any ideas will be great. thanks
  • 221 Answers
The only two things you can do are pull the core of the oven thermostat and re-grease it, but that could throw your temperature calibration way off. The other is to replace the thermostat. Either way, a calibration is probably a good idea.
Posted on Feb 05, 2010
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
I have an ultra line gas oven and when I turn it on it smells badly of gas in the house also the oven has a sound every once in a while like it gets a gust of air. Also it seems like it cooks more on the...
HI,
SAFETY FIRST, Have the unit checked for issues, it not worth the home over a leak. Unless you know about this unit, have your gas company inspect for leaks and supply issues. If you leak is a connection issue, they will advise how to repair, if internal, it should be check right away or prior to using again.
I had seen a simple loose connection cause a lot of damage.
Please be safety, I would be glad to assist you further if needed.
Aug 21, 2011 | Viking 31 in. VGSU101 Gas Cooktop
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
When i use one burner the other one makes the electrical pop
That allows you to light that burenr turn the knob to mid range for the gas on both or full on and it should stop. there is one igniter and 4 burners. Each burer controls the igniter when oven calls for gas.
Aug 29, 2009 | Viking Cooktops
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
The smell of gas
call for service immediatly. dont ever mess with a possible gas leak. it is more than likely a slow leak at the shutoff or the safty valve. your local repair company should have a combustible gas detector. to pin point the leak.
Dec 05, 2006 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
648 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
