Question about HP LaserJet CM1312 All-In-One Printer
When , I scan using the top loader, a red line appears
When , I scan using the top loader, a red line appears on my documents
  • 150 Answers
I would say to clean the glass where the scanner bulb is parked. Just lift up the cover and clean the glass. if you look close you could see a red mark on the glass. Steven
Posted on Feb 05, 2010
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
When scanning a red line appears on my scnned copy and runs throught the document
lift the top as if I were going to scan or copy something. I checked the glass. On the far left is a separate glass area. This is what the feeder uses to actually copy or scan a document. This had a smudge on it. I cleaned the glass and it was fixed.
Jul 27, 2011 | Brother MFC 490cw Color Inkjet...
Horizontal lines on photocopies made but no lines appear when document document is printed.
Hi there, As it sounds its a dirty scanning glass. Open the top of the scanner so that you can see the scanning glass.. If your standing in front of it you will see on the left hand side a strip of thinner glass.. Take a damp cloth (better cloth with spirits/surgical alcohol) and clean the both the small and the large scanning glass. These lines normally cause if the glass is dirty. Especially if your using the document Feeder. As a lot of time wet ink or typex or correction fluid gets stuck on glass which will cause these lines.
Hope it helps
Regards,
Jul 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Black line appears on scanned document
Hi there! When does the black line appears?When you are using the ADF module or when you are using the normal copy glass under the top cover?If the lien is appearing when you are using the ADF open the top cover and clear the little glass from any dust.if the line appears when you are using the normal glass the your scanner unit need cleaning or replacing , for which you are going to need a service help! Please replay if you have any other questions!
Mar 15, 2011 | Brother MFC 7840W Printer
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
HP Scanjet N6010 Once documents are scanned a line appears on the scanned copy
The lines on a scanned document are typicaly caused by dirt on the scanning glass. To clean it use the following steps.
1. Unplug unit.
2. Open the fron access door from the top.
3. Clean both top and bottom **** glass that run the width of the scanner.
The glass can be cleaned with a lint free cloth and a mild glass cleaner.
Jul 21, 2010 | HP Scanjet N6010 Photo Scanner
When I scan or print through the multi page loader on the top of the unit it puts a line down the side of the document
There is a piece of debris in the path of the scanner and document. Check the ADF scanner glass, a small strip to the left, for anything. Use a Q-tip lightly dampened with some distilled water to wipe the glass clean and dry.
Jan 18, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Black line appears on copies fed through automatic top loader
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Apr 21, 2009 | Konica Minolta DiALTA Di200 Copier
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
If you are using the document feeder, chances are something has gotten on the glass recently. Try cleaning the area of the scanner's glass that is to the left (underneath the document feeder) of the main glass.
Mar 20, 2008 | Ricoh Aficio SP-C210SF Printer
HP LaserJet CM1312 All-In-One Printer Logo
275 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
