Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
My friend has a Jenn Air JDR8895AAS that the control panel does not work on. The burners on the top of the oven work but nothing else. What does he need to do?
4 Suggested Answers
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
SOURCE: Do you know where I can get a Oven control
Found a panel from a company in CA...
Posted on Nov 22, 2009
Jul 17, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn aire oven no power.
go to jenn air web site -find your stove model number and find user & care guide that should help you
Mar 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Top burners spark intermittently with burner valves shutoff
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
Sep 11, 2006 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
78 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
