Question about Kenmore 24032\24036 Top Load Washer
Clothes washer What is the discharge rate of my clothes washer in GPM?
  • 5,911 Answers
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Posted on Feb 23, 2008
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
What sort of lpm rate would suit a normal home with fairly good water pressure
This is just what I would say for an average family of four during hours of peak usage. You should be okay with a flow rate of twenty to twenty four lpm,assuming you have rapid enough recovery. This is based on one shower at a time and not running dishwasher or clothes washer at the same time.If you are using hot water from multiple fixtures then increase accordingly.Hope this helps. Thanks
Nov 10, 2010 | Rheem Tankless Hot Water Heater...
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101 .
Oct 10, 2010 | General Electric Clothes Washer Timer Hub...
After spin cycle is complete, clothes in washer are still too wet
Check for obstructions in the pump and discharge hose. Check the motor coupler. Here is a video that should help.
http://appliancehelponline.com/topdirectdrivevideo.html
Jun 04, 2010 | Kenmore 22422 Top Load Washer
Washer spins but water does not discharge. spin
Tip machine back and remove the bottom panel, 3 screws. You will then see a large tube at the front, unscrew in a counter clockwise direction, and remove. Clean pin trap lubricate o ring and replace back into recepticle
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Sep 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water Sounds
Friend,
ngfam1 At your service!
This is normal for the Neptune!
I used to have a Neptune and I sold them too!!
The machine is wringing out the clothes good??
The Neptune comes new with water in ti from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the mold, musky or even stinky smell of the Neptune! Every day i have people here asking what too do about the moldy wet smell!
SERIOUS!!!!!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
GOOD THING WHIRLPOOL JUST BOUGHT THEM OUT LAST YEAR!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
232 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
