Question about HP Photosmart Pro B9180 InkJet Printer
Printer does not recognize paper size. Every reply is paper too small from bottom tray and sheet feed.
  • jpcreel3 Feb 05, 2010
    Tried several size settings smaller than paper inserted in printer. Didn't work!
  • 1,428 Answers
Reinstall the printer.
Hope it helps.
Posted on Apr 15, 2010
  • 163 Answers
You may have to change the settings of paper size in the printer systems settings.
Hope this helps!
Posted on Feb 04, 2010
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
Paper jams in first rollers out of paper tray one sheet will feed but several will jam
Check for wear on the first set of rollers. If they seem fine and your print settings are correct (media type and size) then you may need to replace a small part in the paper tray. When I have seen this issue previously I needed to replace a seperation pad that lifts paper up(spring loaded to raise the paper the right amount as the paper level goes down) and has a rubber pad on top, when the rubber pad gets worn and it no longer 'holds' the bottom sheets that are not supposed to feed.You can get these from brother directly or from service centers/retailers. The part you need is the paper feeding kit, part no. LM6291001 and it looks like this!
Aug 22, 2011 | Brother DCP-7020 All-In-One Laser Printer
Why is there a black stripe on the backsid of the paper when I try and print?
you need to clean the bottom plate, heres how:
1 Make sure that the printer is on and then remove any paper from the Rear Tray.
2 Press the Open button to open the Paper Output Tray and extend the Output Tray Extension.
3 Fold a single sheet of A4 or Letter-sized plain paper in half widthwise, and then unfold the paper.
4 Load this and only this sheet of paper in the Rear Tray with the open side to the front.
(A) Load the paper after unfolding it.
5 Open the printer properties dialog box.
6 Click the Maintenance tab, and then Bottom Plate Cleaning.
7 Confirm the displayed message and click Execute.
The paper cleans the inside of the printer as it feeds through the printer.
Check the folded part of the ejected paper. If it is smudged with ink, perform Bottom Plate Cleaning again.
Important --
Even if the Cassette is selected as the paper source, paper will be fed from the Rear Tray.
Do not perform any other operation while the bottom plate is being cleaned.
If the problem is not resolved after performing cleaning twice, the protrusions inside the printer may be stained. Clean them according to instructions. See Cleaning the Protrusions Inside the Printer.
Apr 02, 2010 | Canon Pixma iP4500 InkJet Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
What is message: 41.3 paper error ?
Hi there
41.3 on a lj 4+ is a paper Feed related error normally caused by dirty or worn paper feed tyres if you are getting this error whilst feeding from the paper tray at the bottom of the printer stack a few sheets on the manual feed tray on the front if you dont get the error
clean all your feed wheels or order a service kit and replacement replacement tyres
Regards AL "alstech"
Jun 07, 2009 | HP LaserJet 4 plus Printer
Printer error message
Will it not feed a sheet of paper? The feed track of an HP is very convoluted. Take paper tray out and try a vacuum cleaner suck to ensure no paper debris is sticking somewhere, 'Knock up' the paper pile and ensure it is fully inserted in the tray. Turn printer off then on See what happens. Also take a look at www.fixyourownprinter.com
May 28, 2007 | HP DeskJet 812c InkJet Printer
HP Photosmart Pro B9180 InkJet Printer Logo
404 people viewed this question
Seeker5211
Seeker5211
