Question about Linksys WRT160N Wireless Router
I have 51% on my laptop connection to a wireless source and it shuts off my computer and locks it up. It is a card that slides into the side of my Dell. Do they lose their strength after time?
  • 163 Answers
They do tend to lose their coverage strengths after time yes.
Hope this helps!
Posted on Feb 04, 2010
I'm having problem connecting to the wirless internet on dell lataqitude e5500. The wireless is on but im unable to connect to any wirlesss networks? Can this problem be solved?
If you are using a firewall disable it there is a wireless toggle switch on the side of your laptop. It slides back and forth to turn your wireless card on and off. It has a little wireless symbol next to it, and you should NOT see red. If you see red showing, it means that the wireless adapter is turned off. Slide the adapter to the ON position, and then try to repair your wireless connection. Hope this helps
Sep 01, 2011 | Dell Latitude E5500 Laptop
Cant find how to connect to a wireless network with my cf-51
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 23, 2011 | Panasonic Toughbook CF-51 Notebook
Where is the CMOS battery on the HP G60-235DX? How do I remove it? Also, what type (model #) of CMOS battery does this laptop have?
Shut down your laptop and disconnect all power sources. Turn the laptop over and lay it face down.
Remove the screws that secure the hard drive cover and remove the cover. Take out the remaining screws that secure the hard drive to remove it.
Locate the RAM (random access memory) and wireless card cover. This is often located in the center of the laptop. Remove the retaining screws and take off the cover.
Remove the RAM module by spreading the retaining latches on each side. Tilt the RAM module at an angle and slide it out of its compartment.
Disconnect the cables from the wireless card and remove the screws that secure the wireless card to the motherboard. Remove the wireless card from the laptop.
Locate the CMOS battery. It is about the size of a coin and is secured by a clip. Unclip the CMOS battery and remove it from its compartment. Insert the new one and reassemble the laptop.
Here's a link to a video that shows you how to do it too. http://www.ehow.com/video_4984398_change-laptop-battery.html Hope this helps! Don't forget to rate.
Dec 21, 2010 | HP G60-235DX Notebook
My laptop quit working cant get no connections through router
First; Does your laptop see any wireless connections? If no wireless connections are showing up, your wireless card could be off. Depending what type of Computer you have, it could be a slide switch in front, if its dell, you can push Fn and F2, If you do see wireless connections, and just cant connect,. try shutting down your Computer, unplugging your Modem, and Router. Restart, then see if you can connect. Wireless has so many issues, If you still can't connect, let me know and I will give your more information. Hope this helps.
Oct 12, 2010 | Belkin (F5D7230-4) Router (587009)
Do i need a pc card for my wireless connection i have an acer 5050
No the laptop has an in-built wireless card so there's no need for an add-on.
The switch is a slide switch which is at the very front of the laptop on the left hand side of the headphone and microphone jack.
When you slide the switch a LED will come on.
Regards.
Jul 15, 2010 | Acer Aspire 5050 Notebook
On my e5500 it does not see wireless networks this morning
Hi, there is a wireless toggle switch on the side of your laptop. It slides back and forth to turn your wireless card on and off. It has a little wireless symbol next to it, and you should NOT see red. If you see red showing, it means that the wireless adapter is turned off. Slide the adapter to the ON position, and then try to repair your wireless connection. Hope this helps!
Mar 08, 2010 | Dell Latitude E5500 Laptop
Dell Insperion M1540 Dell wireless broadband card
the side of the computer is usually where it is, it slides up.....
Nov 19, 2009 | Dell Inspiron 6400 Notebook
I have never used a laptop computer only the desktop. I just pu
Your battery pack gets inserted on the underside of your laptop, it slides in and locks on.. Line up the track and simply plug it in.
What wires are you referring to that came with the laptop?? what do they look like?
You only use your modem if you're planning in using DIAL-UP for your internet connection... Otherwise you'll never need it..Your modem port is the one that fits a telephone cord plug... the wider one that looks similar is your Ethernet port - which is used for either dsl or ethernet/cable connection...
Bluetooth is a means of connectiong perifferals to your laptop such as a cell phone, a PDA, a headset....etc.... Its a short range wireless connection method..
Wifi is your wireless connection wireless Wan is Wide Area Network.. mainly used for business and Companies that have servers overseas and such..
Wifi Wireless LAN is local Area Network... Which is what you would be considered if you use Wireless to connect to internet..
To Use Wireless You Also Need A Wireless Capable Router/Modem
Analog Phone Line Is THe "old Land Line Connected Phone" as apposed to a digital phone...
the LCD panel is referring to the Screen of your laptop.. The LCD Panel is made up of Layers Of Films, A Backlight Panel, LCD Bulb, and A Glass Digitized Panel
You turn off the Power Either By Holding Down Your Power Button until it completely shuts down, or shut it down through windows... START/Shut Down
KeyCaps are the Additional Key Functions that all laptops have... To access these Key Functions, You Press The Function Key (Fn) along with the corresponding F-Key or other key...
Storage media refers to any media capable of storing data... Such as a secondary hard drive, A Media Card, A Thumb Drive A Flash Drive A Camera Memory card... etc....
Doubtful that you have a floppy drive on that laptop... But if you do, the standard 1.44 Floppy Disk Works
To make a backup, If its a FULL backup, you will need to use DVDs or better yet, use a Flash Drive (USB thumb drive), or you can get yourself an external hard drive to store your backups onto...
Expres card is the wide slot on the side of your laptop,,, Used for Different cards, Wireless cards, Ethernet Cards, Extra Usb Slots Card, Data Storage cards.. Etc...
Nov 16, 2009 | Toshiba Satellite M35X-S149 Notebook
Dell e1505 shuts down all power sources when plugged in
HI, CHECK THE MEMORY CARD AND VIDEO CARD, FIRST UNPLUG THE PC REMOVE TWO SCREWS FROM THE RIGHT COVER SLIDE BACK THE COVER, YOU WILL SEE ON THE RIGHT UPPER SIDE OF THE MOTHER BOARD ONE OR TWO RECTANGLE LONG BOARD/CARD THAT IS MEMORY CARD, ON BOTH END IS A LOCKING TAB, BEFORE YOU TOUCH THE CARD ON LEFT HAND TOUCH THE MAIN FRAME OF THE PC THEN PUSH BACK THE LOCKING TABS TOWARD TO THE MAIN BOARD THE MEMORY BOARD/CARD WILL POP OUT. CLEAN THE CONTACTS OF THE MEMORY BOARD /CARD, REINSTALL IT BACK, IF THE PC DID NOT TURN ON .YOU NEED A POWER SUPPLY TO BE REPLACE.
MAKE SURE YOU BUY THE SAME POWER SUPPLY YOU HAVE ON PC. YOU CAN SEE THERE IS A LABEL ON THE POWER SUPPLY WHAT IS THE WATTAGE. HOPING THAT THIS MIGHT HELP YOU SOLVE THE PROBLEM.
HH
Aug 14, 2009 | Dell Latitude D600 Notebook
Linksys WRT160N Wireless Router  Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
