Question about Dell A215 Computer Speakers
Power supply specs for Dell A215 speakers?
I received a pair of these and all I can get them to do is buzz loudly. I think it's possible I may have been given the wrong size power supply. What are the specs for this particular pair? Thanks
3 Suggested Answers
  • 112 Answers
SOURCE: where can i get the power cord for a pair of dell
dell webites or try to find it on google
Posted on Jun 20, 2010
  • 905 Answers
SOURCE: I brought pair of Dell A215 speakers w/o power
There are universal power adaptors available but I don't think it is worth spending the money trying to get these speakers to work unless you are sure they are not faulty and you really REALLY like them. There are much better speakers available than these, with better sound and greater volume. These speakers are rated at a very poor 1.5 Watts each.
If oyu still want to try another power supply then check the details of what power supply is required. There should be a label on the back - I believe this model requires 12Vdc at 0.5A. You can use a power supply with an output higher than 0.5A but do not use one with less than 0.5A. The power connector or jack also needs to be the correct polarity, usually the middle pin or internal connection is the positive and the outer pin or connection is the negative. I do not know what it is on this model.
Posted on Feb 27, 2011
My speakers just out of the blue began to buzz in the middle of a song. The volume was low & did not seem to effect the buzzing - after I turned music off speakers began to make a high pitched ringing...
I've never worked on this model so I can't give you a definite part value or location, but you'll probably find a bad filter capacitor (or possibly more than one) in the power supply. The power supply converts the AC power line voltage to the DC (direct current) needed by the electronics. If the filter capcitors don't work, the result isn't smooth and steady, and the result is an annoying hum. You're probably hearing this.
It's possible to replace the bad capacitors, but it's not always easy. The people who make computer speakers don't often design them to be serviced, and sometimes it's a challenge getting into the power supply. But if you or someone you know with some electronic soldering skills is willing to give it a try, you might be able to bring these speakers back to normal. Good luck and thanks for using Fixya!
Jun 01, 2011 | Dell Ay410
I brought pair of Dell A215 speakers w/o power source. I tried several power supply cords that fit the outlet. They won't work. Do I need to buy a SPECIFIC power supply cord? Is there such a thing as a...
Don't just randomly plug power supply's in; check and see what it needs.
It should be printed somewhere on the device how many DC volts it needs.
If it needs 9volts, get a 9volt power supply.
If you don't have a power supply the same size as it needs, order one off of Amazon, or eBay.
-Forest
Feb 27, 2011 | Dell A215 Computer Speakers
My speakers are plugged into my pc but there is no power to them...the green light doesn't come on when I switch the speakers to on mode!
there s a possibility that there is something worng with the power supply of the pc,you can also check cable connection
Jun 26, 2010 | Dell A215 Computer Speakers
A215 speakers fuzzy noise
Have you got a power supply unit near the speakers (move any power source away from a speaker). Other than that then one of your cables has a short in it.
May 17, 2009 | Dell A215 Computer Speakers
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
May 04, 2008 | Onkyo TX-SR875 Receiver
Dell Speaker 215 problem
Would suggest that when you plugged in the router power supply it supplied a HIGHER voltage and you have blown the speakers.
May 07, 2007 | Dell A215 Computer Speakers
Dell A215 Computer Speakers Logo
236 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
