Question about Sony KDS-R60XBR1 60" Projection HDTV
Sony 60 I have notice that my TV keeps shutting down for 30 second intervals. The picture goes out and then comes back. the green LEE flashes just like when I first turn it on
  • 3 more comments
  • joea42 Feb 20, 2008
    I unplugged the TV for 3 hours. I will see if this fixes the problem
    I live in Newport, Ky 41071. Are you taling about the TV remote or the cable remote? I will try both when I get hme and see if this fixes the problem.
    The LED is green and it blinks until the picture come back and them it turns to a solid green. TV tier is not set.
    Yes I am home. I have tested everything except for pulling the red wire on the power supply. I am not comfortable doing this.
    maybe I wasn't clear. I never get a RED Flashing LED. I can be watching a TV show and all of a sudden the pictures goes blank, the GREEN power LED is flashing like someone turned the TV on. It goes a solid GREEN and then I can watch the TV show again. this happen all night long and I finally turned the TV off. It was too painful to watch.
  • joea42 Feb 25, 2008
    Thanks to all. I unplugged my TV for 3 hours and changed the remote batteries and I worked great all weekend.
    Thanks again,
  • 552 Answers
 You could test to see if the HV splitter is the problem by disconnecting the HV anode (big red wire) from the flyback transformer (not the splitter since that will arc), unplug the tv,power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Posted on Feb 20, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 23, 2008
    If you unplug the tv, let it sit overnight and wear gloves while removing the big red wire from the flyback transformer, it will be safe. Plug the tv back in and then see if it stays on.
    If you would rather no do that then you should call a qualified technician, possibly one from fixya, if there is one in your area.
  • Sony Master
  • 19,396 Answers
Probably a cold solder joint in the high output power supply. This happens when hot /cold expansion/contraction eventually breaks a solder bond on the component board. cost about 80pounds/$125 to fix it
  • Ginko
    Ginko Feb 20, 2008
    Try also taking off your remote battery. It is rare, but remote faut can cause same problem
  • Ginko
    Ginko Feb 20, 2008
    I think you will need to call the service, where are you located?
  • 689 Answers
Its a pattern to indicate power failure
  • ExpressFiX
    ExpressFiX Feb 20, 2008
    you may unplug the TV about 2 hours if issue persist best solution to have assistance of hands on technician or contact to Sony if its in warranty
    Brigadier General:
  • 3,614 Answers
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
  • 1 more comment
  • micromaster
    micromaster Feb 20, 2008
    The LED blinks when the TV is turned on, then shuts off when the picture is displayed.
    If the red LED blinks continously this may indicate the TV need service.
    When Lit, indicates that the timers is set. When the timer is set, this LED will remain lit even the TV turned off.
  • micromaster
    Are you at your home now, and test everything posted here?
    Have a manual available?
  • micromaster
    I provide this one for you.
    Let's try for some of these explanation for LED indicators.
    click here.
    pp.16 / 101 / 106
    Advice me any result, i'll catch with you again later.
    Thanks,
    micro
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Problem with Sony KDS-60A2000 60
Hello
The power supply regulator board has the fault. There ie no repair to this board. You have to replace it as card basis.
This is the picture of the said power supply board to your Sony TV.2_5_2012_4_35_40_am.jpg
Feb 05, 2012 | Sony KDS-60A2000 60" HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
TV goes to green, sound stays on a few seconds then TV shuts off.
Sounds like you have a bad picture tube. More than likely the CRT could be shorted, which would cause the set to shut down.
My first advise would be to power up the set with an isolation transformer with the voltage about 60% approx. 72 Volts AC, and monitor what happens when you increase the voltage slowly.
If the set remains on at 60 -70 %, then when increased to 90 - 100% it shuts down, you have something drawing too much current ( which could be the CRT )
Sep 14, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Jun 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDS-R60XBR1 60" Projection HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
