Question about Canon imageRUNNER C5180 Color Copier
I would like to set the default copy to black and require users to choose color when they want a color copy on my Canon c5185. I can't find where in the menu's to make this change, help please.
  • 58 Answers
You can find it in the additional functions under the common settings
Posted on Feb 10, 2010
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
Tried the solution to set black as the default color on the Canon ir c3200 that was on your site, it says to set as B/W on screen, only gives Auto Color Select, Full Color and Black as choices. Says to go...
might be able to do this through your remote user interface {the copier ip address} go to internet expolrer and type the ip into the address bar and look around for settings under additional funtions
Mar 26, 2010 | Canon imageRUNNER C3200 Copier
Canon IR C5185 printing black copies, would replacing black drum fix the problem?
replace the black charger... if the copies are coming out strongly black with no white lines then your drum is good... the charger died...
Dec 08, 2009 | Office Equipment & Supplies
How do I sent my Canon ImageRunner C3220 to copy in black and white as the default?
First set it to B/W on screen then in additional functions /copy settings/page down to store settings then store and reset to quit.
Nov 24, 2009 | Canon imageRUNNER C3220 Color Copier
Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
Need to set default for black/white copies not autocolor
set the machines control panel to the settings that you want and then press the PROGRAMS button and choose set as default and the screen will always be as you set it.., Good luck
Apr 30, 2009 | Canon imageRUNNER C3200 Copier
Set for copier to make balck ink copies no color
on the lcd screen upper leftarea touch the area where it says auto color then set it to black. then touch add function copy settings scroll to the one that says standard setting it will ask you if you want to set the setting then set it in . the default screen now should stay in black
Jan 30, 2009 | Canon imageRUNNER C3170I Color Copier
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Default copying to black and white on a Konica Minolta Bizhub C353
I have a Konica Bizhub C353 - to set the deault copier setting to Black as opposed to Auto:
** first select black on the copy screen **
* Utility/Counter >> User Settings >> Copy Settings >> Default Copy Settings >> switch from "factory settings" to "current settings"
please note: you may need to do this twice (and be sure before you go into user settings that you select black on the copy screen)
I don't think the factory wants you to know how to do this - I couldn't find it in any user manuals and figured it out merely by trial and error!!
May 12, 2008 | Office Equipment & Supplies
Canon imageRUNNER C5180 Color Copier Logo
432 people viewed this question
old marine
old marine
