Question about IBM ThinkPad R40 2722 Notebook
Ibm r40 2722
I have the above machine.
It has had a recon motherboard and up graded cpu 1.8GHz.
I put machine back together by placed parts around base to test machine is working.All works discs install.
Great I thought.
I completly built up laptop an screwed all parts together.
When I came to power up all works accept no discs will install or can be read.Keep getting setup.exe or d:\ faults.
I don't understand why fault has appeared only since I put it back together.
  • 16 Answers
Check in all the connections and chek in the status of the dics if you feel is connected properly, in device manager.
at the end recheck all the connections and just press the disk so as to confirm the correct connectivity
Posted on Feb 20, 2008
My son's dad came over and took apart my 1978 Yamaha GS80 to check carb and clutch. He never put it back together. How can I do this
Hi, Anonymous the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Apr 02, 2012 | Yamaha Motorcycles
My motherboard K8 Trinton ga-k8nsc-939 soket retention plate snapped the cpu is now loose, please advise on how to repair this this prolem.
Hello boraz
By retention plate do you mean the handle that locks the CPU in place.?
if that is the problem there you can not replace it HOWEVER you can still use the motherboard.
note that the CPU socket is a two section structure on top of each other. after inserting the processor you can slide the two section together to hold the CPU. you have to glue the two section together to make it stay in place.
the draw back is that you probably will not be able to upgrade the CPU in future because of the glue.
hope this was helpful.
good luck
Feb 08, 2011 | Intel Motherboard
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Up-grade
you *might* be able to find a better video card, or more ram, or even a faster cpu for $20 on ebay, but a computer that old is more in need of replacement.
Mar 15, 2009 | Computers & Internet
Computer won't boot-up
hi, is the ide-ata enabled in the bios? do you have sata? and is it enabled?also did you put thermal compound on the cpu' s heatsink when you put it back on the cpu? the 2 second on thing sounds like over-heating,do check the bios first. alot of motherboards have a thermal shutdown, so if the fan or compound failed, it would quikly shut off. as for the channels not working-you can try your primary drive, and see if it boots. but first see if it is on in the bios. check and replace the battery on the motherboard. post again if you need help good luck! hope this is helpful.
Mar 10, 2009 | Intel Computers & Internet
FOR IBM MOTHERBOARD REV 1.6
I believe the fastest CPU you can install in that motherboard is a Athlon XP 3200+ (2.2GHZ) socket 7 CPU.
That board uses eaither DDR 1 or SD-RAM and is definatly not compatible with DDR2 which uses a different connector on the motherboard (more pins)
Jan 21, 2009 | IBM (09N5424) Motherboard
IBM 25P2590 P4 micro motherbord
i found nothing but items referencing updates and patches to existing servers and software to accomodate the situation you describe.. if you're still nervous try looking around on ibm.com/support or lenovo.com/support
Dec 29, 2008 | IBM (25P3294) Motherboard
No display or POST
WAS THE POWER SUPPLY WORKING? IS THE 4PIN BLACK AND YELLOW CONNECTOR FROM POWER SUPPLY IN PLACE? DID YOU TRY BIOS CLEAR? IF IT IS NOT A NEW BOARD - CHECK FOR BLOWN CAPS AROUND CPU (UPRIGHT CYLINDER TYPE THINGIES. RESEAT RAM. CHECK IF MAYBE ONE OF 24 PIN ATX CONNECTOR DIDN'T PUSH OUT OF SLEEVE.
Nov 06, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Ea7ecp@hotmail.com
Changeing a cpu is a simple process.
First step, remove the cables and open the case.
locate the cpu - heatsink
it debends on what kind of heatsink it has, simply turn the lever
or use a screwdriver to unhook the metal connector. If you don't have enought room you might need to remove the powersupply first.
handle the cpu with care, ones the heatsink is removed you can
pull up the lever next to the cpu to unlock it
now you can remove the cpu with your fingers by the edges.
place it in a safe location, and go ahead install the new cpu.
optionally apply some thermalpaste and attach the heatsink
and the power connector for the heatsink fan.
you are done.
Jun 11, 2008 | Soltek SL-85DRC Motherboard
IBM ThinkPad R40 2722 Notebook Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
