Question about Ryobi ROUTER KIT P163K
My Ryobi router is not working at all. It spins
My Ryobi router is not working at all. It spins freely by hand but acts like its getting no power. It is not the outlet.
  • 3,740 Answers
It can be any number of things that cause this:
1. Broken power cord
2. Failed on off switch
3. Failed trigger switch
4, Brush or brush tube assy failure (Most common failures)
5. Open armature winding
6. Open field winding
If you can not get continuity across the power cord with the switch on and trigger switch depressed yhe only option for further troubleshooting is to open the unit.
You can go to this page then click on go to power tools store and under model number use R161
http://www.ryobitools.com/support/parts_batteries
The manual lists all 50 parts in your unit.
Item 16: Brush assy part # 968304-026
Posted on Feb 04, 2010
Motor problem on Magimix 5100
The unusual sound and the fact that the spindle spins freely by hand makes me suppose it is a gearing issue. Spare parts are expensive. Check here, if it helps: http://www.ebay.co.uk/itm/Magimic-5100G-Food-Processor-and-Accessories-/182318641344
Regards,
Dan
Oct 19, 2016 | Heating & Cooling
Model R163GK router. Where can I get a working manual?
The user's manual for the Ryobi R163GK fixed base router is available from Home Depot on the product page: http://www.homedepot.com/p/Ryobi-8-5-Amp-Fixed-Base-Router-R163GK/205179539 . Look on the right hand side of the page for the Use and Care Manual. The direct link to the manual is http://www.homedepot.com/catalog/pdfimages/de/deaea807-a602-4a2e-b637-e30019a5f34f.pdf .
I hope this helps. I think the K indicates that the unit was for Home Depot sales; the router is the same as the R163/R163G. Ryobi has the same manual here, https://www.ryobitools.com/power-tools/support/manuals , if you leave off the K.
Feb 23, 2016 | Ryobi Tools & Hardware - Others
What would make the foot peddle not work. The machine is plugged in and on.
Does it spin freely if you spin the wheel by hand, or could there be some thread jammed inside? Do you hear it buzzing like it's trying to start spinning, or is there no indication that the motor is getting power?
Jan 24, 2015 | Sewing Machines
Ryobi homepage
Yes. There should be a shear pin through the shaft. Disassemble the mechanism and replace the pin. It's designed to protect the shaft from damage.
Sep 07, 2014 | Garden
Blade revs fast, doesnt get up to speed before it binds and smokes.
Remove the belt and try to spin the blade. If it still acts that way, you need to replace the arbor bearings. If it spins easily and smoothly and has no play side to side, then the motor is the problem.
Feb 05, 2013 | Saws
Chainsaw starts great, but chain wont go
When you tighten the two side nuts, make sure you haven't jammed the chain on the gear. The chain must move freely(by hand) while tightening and when at proper adjustment
Sep 22, 2010 | Ryobi Factory Reconditioned 18" 40cc...
My fan stop working the blades are not turning and all it does it's a noise but it don't spin
Is this your indoor fan (this isn't a window unit is it)? Turn the power off and make sure the fan spins freely by hand. If it does then check the capacitor for the fan. If it doesn't spin freely then you may need a new fan motor.
Aug 23, 2010 | Heating & Cooling
Runs but acts like in bind when gased
Did you recently take the shaft off of the trimmer? If so, you didn't get the drive shaft seated properly. You will have to take the shaft off again and try to seat the shaft again. You may have to pull on the rope slightly as you fit the shaft into place.
Jim
Jun 08, 2009 | Ryobi 15" Electric Factory Reconditioned...
Drill quit working
what you are missing is a dewalt hammer drill.
Apr 25, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Ryobi ROUTER KIT P163K Logo
471 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
