Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
I NEED TO GET THE POWER SUPPLY OF THIS MONITOR. MAY YOU TELL ME THE FEATURES AND WHERE CAN I GET IT. THANKS
  • 163 Answers
You should be able to get the power lead for your monitor from the manufacturer or online on auction sites for pretty cheap.
Hope this helps!
Posted on Feb 04, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
I NEED TO GET THE POWER SUPPLY OF THIS MONITOR. MAY YOU TELL ME THE FEATURES AND WHERE CAN I GET IT? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
I have an LG L1952HQ LCD monitor that shuts off every 5-10 sec. it's not the PC going into power saver or srceen saver mode
greatatuin1, Tell me the "date of manufacture" from rear of unit!! You may need to inspect the units power supply printed circuit board or black-brick switchmode power supply. Is power supply "lay on floor" type or internal to monitor case? Is your pc working ok with "differerent" monitor?? Have you been to youtube to watch "refurbishment" DIY videos of cold cathode-fluorescent-lamp back-lit lcd monitors??? If unit is really old and has lots and lots of "on" hours, you may even need to replace the CCFL lamps also. Tell me more info, so I can advise you. Symptom seems to be "black screen of death" !! Have you performed or even know the "flashlight test" that every ccfl lcd monitor owner should know??? Do additional comment back to me. 12fixlouie
Oct 24, 2010 | LG Computers & Internet
Self test feature check stuck on screen
from my past history dell has/is problems with the E153pc and the E172pb is it under warranty and have you gotten hold of dell about this I have had cases where they have replaced monitors.
sorry it was no great help but dell knows of this problem. dont let them bull**** you.
Jul 21, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
E153PFc Dell monitor: cannot change resolution
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating red/green/blue/white dialog box should appear on screen against a black background. What appears?
Jul 17, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
I need to find out what power sources I can use for my monitor
You need a 10-14VDC power supply. Is this in a car or home?
Dec 27, 2008 | Clarion VMA5894 5.8 in. Car Monitor
Need power supply board for H21 LCD monitor
H-21 scan port Dark Screen, If you unplug the green light flashes 2 or 3 times ending any activity until completely unpluged and plugged in again. My other scan port works fine using 1st monitor cables. I've used both ports on the graphics card. It's definately the monitor power supply or other componant.
Any ideas?
Bill
Nov 12, 2008 | Scanport H21 21" LCD Display Monitor
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Flat panel hp f1503
Most likely you have degraded electrolytic capacitors in the internal power supply. If you can disassemble your monitor to liik at the power supply board you might notice bulging capacitors which if replaced will likely restore normal function.
Mike
May 29, 2008 | HP vs15 15"LCD Flat Panel Monitor
How to test power supply
Test the power supply to ensure that it is turned on and that it releases its reset signal.
Good Luck ! Please dont for get to Vote/Thank You.
Dec 16, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
216 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
