Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag MDB6601AWB problem
Left door spring and balance cord have come off...door just flops down. How can I reattach the spring? Is there a diagram somewhere to illustrate this?
Thanks!
BTW, I called Maytag and they could not/would not provide this.
  • 552 Answers
Http://www.partstore.com/
They have the spring for sure don't know about the cord.
You may have to call them for that part.
They have a number on the website
Posted on Feb 20, 2008
This web is very beautiful
My balance for the drum in my washer came out, how do i reattach
sounds like maybe one of your drum support springs has perhaps broken.
Sep 16, 2016 | Maytag MHW6000XG Maxima High-Efficiency...
The dishwasher door no longer has a return spring. It just flops down.
Bob, make,model# and order spring and replace, not hard to do.
Check that your spring, just did not pop off first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 24, 2016 | Dishwashers
Door will not stay shut
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can download Whirlpool owner's manuals, installation manuals, and parts lists here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Jan 19, 2014 | Maytag MMV5165 Microwave Oven
My Dishwasher door has suddenly become very heavy, there is a cord hanging down on left hand side its a HJA8630 about 5 years old can you help
The cord you refer to is part of the door spring assembly, you need to take off the bottom panel and repair or replace the door spring or cable.
Jun 04, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
The spring came off the door. how do you put it back on it was on the side of the dishwasher.when you open it just flops down find the spring on the floor.do you have picture of where it goes
Remove the bottom toekick panel from the front of the dishwasher.
Look just inside and you will see spring mounting holes on the bottom support frame.
The spring goes from a hole to the hole in the lower door hinge.
If I had a model number I could be more specific.
Sep 14, 2010 | Maytag Dishwashers
Door is not staying up when open banging down
There are arms that come off the bottom of the door frame that should have support springs attached as a counter balance. They do break from continual use and stress. If the toe kick inspection panel is removed the springs should be visible, one on each side at the front. If broken, replace them. If one or both have fallen off, reattach them. There are different holes to attach them through, for more or less strength. Replacements should be available through an appliance parts store like APCO. Or perhaps Sears parts.
Oct 22, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
The door flops open as the rope has broken. I have the replacement part but need a diagram to show how to replace the part. Where can i find the diagram?
Documented in the manual...The plastic part goes on the metal hinge on the door...follow the rope down to the top wheel (clockwise and around) to the bottom wheel (counterclockwise and around), attach to the spring.
Apr 12, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
394 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
