Question about Eureka Capture Upright Vacuum Vacuum
Where do I buy a belt and a filter and would I be able to replace it by myself? I need the cheapest deal, since I just lost my job
  • 701 Answers
You can get the replacement belts here for really cheap and you can view the manual which has instructions:
Eureka Capture Belts
Posted on Feb 05, 2010
Dyson 33 not sucking up good anymore -how can I fix this?
If the suction is good it could be the brush roll is not doing it's job. If the bristles are worn or frayed or the belt is slipping your vacuum may work ok on hard surface floors but will not do a good job when vacuuming carpets. Your model has two belts in the clutch assembly. When these belts lose elasticity the belts will slip rather than turning the brush roll at the proper speed when vacuuming carpets. The carpet fibers create a lot of resistance to the brush roll so a belt that appears good may not be working properly when used to vacuum carpeted floors even if the vacuum has great suction. I would recommend replacing the brushroll if needed and the belts or the clutch assembly.
Oct 14, 2017 | Dyson Vacuums
The belt broke and not sure if I try to fix myself if that will void warrenty. Have 1 more year left
No, Replacing the belt is one of the maintenance things you can do without voiding your warranty.
Do you have a place to buy one, or would you need me to find a website for you online?
Handie Andie
Mar 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I was replacing the belt on my Eureka Smartvac 4870 and one of the felt gaskets (or part of it) popped out. I thought I put it in correctly, but the first I used it after replacing the belt, the gasket got...
I'm no expert but if you mean the felt on the roller, you have to replace the roller (expensive,esp. for such a minor part). So. I found some felt with adhesive in the craft section at Wal-Mart, trimmed it to fit and done deal. Felt reduces friction.
Dec 08, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vax turboforce not picking up
Hello Guest, Please check that your brushbar is turning, if isn't then your belt has broken, once replaced your machine should be fine.
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 11, 2010 | Vacuums
Not picking up dirt
clean ALL the filters or buy new one it would be better to buy all new filters also check for clogs in the vacuum also check the belt if the belt is broken it will not pick up much 1. check all tubes for clogs if still dose not pick up 2.check the belt and replace if broken if it still dose not pick up 3.do the filters that worked on my bissell
Feb 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
Replacement of the belt instructions
should be just 2 screws by the beater brush, bottom front of the machine, pop them out and remove brush to remove hairs etc. put new belt in .
Jun 15, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
My filter queen majestic needs help
Try replacing the belt. It's not a difficult procedure, just unplug the machine, turn it over, remove the two screws which hold the chrome plate on and you will see the belt. Take the roller brush out by pulling up on one side, then remove it from it's housing. Then you will see what will probably be a worn out belt, rough on the inside and stretched. Replace the belt making sure to rotate the roller to ensure proper alignment. Then replace the chrome plate, and plug it in.
Oct 22, 2008 | Filter Queen Majestic Canister Vacuum
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Fitting a new clutch.
Hi.
Yes it can be replaced.
Its a lot to explain so try this site It has manuals to do this job.
http://dysonmanuals.inc.io/
Chris..
Dec 10, 2007 | Dyson DC14 Full Access Bagless Upright...
Eureka Capture Upright Vacuum Vacuum Logo
213 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
