Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have a belkin router hasnt been used in a year or so, cannot remember the SSID to save my life. How do I reset it?
    Scholar:
  • 130 Answers
Pull out the plug, hold the reset button with a pen or something and plug it back in. Let go of the reset button and it should be reset to factory settings.
Posted on Feb 04, 2010
  • 163 Answers
The SSID should already be there on the router.
Hope this helps!
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
My belkin G+ wireless router model: F5D9231-4 v2 security is lock and i cant log into my laptop
If you have forgotten the password, reset the Belkin by pushing and holding the reset button for 30 seconds or so and release, this will reset to default settings. Connect and reconfigure the SSID and Security Key. You may want to write down the password and store for future use. Belkin Support: http://www.belkin.com/us/support-article?rnId=6939
Dec 27, 2012 | Belkin (F5D7231-4) Wireless Router
Need to reset network passcode
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
Dec 28, 2011 | Belkin F5D7234-4 Router
From I read online need to reset my belkin router. How doi reset my belkin router so I can use my laptop. The model number is F5D7234-4-BC v1
In the back of every router there is a little hole that is used to reset it. Sometimes is just colored different and some times it says reset next to it. It would be the only one. Just use a pen or paper clip and push in gently so the little rubber depressor does not break and hold it in for 30 seconds(make sure you do 30 sec on a watch nut quick counting). Router needs to be ON when doing reset. Once reset is done you might have to disconnect power to it for another 30 seconds but only if your internet is not working. Hope this helps.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you could give...
Check on the underside of the unit, there may be a sticker with your SSID on it. If you need to you can also reset the password back to the factory default by holding down the reset button. You can also download the instruction manual from here:
http://www.belkin.com/IWCatProductPage.process?Product_Id=509868
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 21, 2010 | Belkin Wireless Play Router (F7D4302)
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you...
Hi this is not a problem any more for you
  1. the password and SSID default is not important any more
  2. lets we make it manually
  3. open one explore and erase the address bar htt://xxxxx
  4. need to be blank the address bar and type (router)nad press enter
  5. belkin setup page will be open and you can make all configuration needed for you new SSID and Password
  6. left side under the Logo Belkin you will see a the menu for setup
  7. go to channel and SSID click and if the router ask you for some password just click Submit and the next page will be open
  8. for default SSID is Belkin XXXX now erase all and type your new SSID one name only no numbers and click in to apply changes
  9. after that go to left side again and next to channel and SSID line there is a Security click again and if ask you a password remember just click on to submit(no password needed)
  10. Ok now you are in security mode click the security mode and change to 64bitwep or WEP only after that will appear one area were you need to input your new password 10 numbers and click apply changes.
  11. Next disable wife protect setup and firewall in to your router .
Ok your new SSID and Password is setting just look for your wireless signal and be connected
any problems just ask me for a remote your PC.
Good Luck don't forget to rating me kk thanks
I have lost my security code and cant use wireless
http://en-us-support.belkin.com/app/answers/detail/a_id/48
all routers have reset button on them, you can reset the router to the factory settings and set up yor wireless with the new code
Jun 19, 2010 | Belkin (F5D8231-4) Wireless Router...
Just bought second hand router belkin 54g trying to set up with ps3 it is asking 4 a wpa key and i dont know what to do can you help
the old owner of your router know the wpa code he/she inputed you must ask him wat is the wpa code since you are now the new owner you shold chnage also the old wpa code to new one....
Oct 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless set up laptop only has wireless slot for card no phone plug ins. no other computer. how do i set this so it will work?
u can not connect any phone to the router first connect a pc through the router and login to teh router screen >and go to wire less settings and enable ssid broad cast>and change teh ssid name which u can easily remember one and save settings>and reboot all teh w/l laptops>and click on the right side w/l i-con>and search for teh ssid that u changed and click connect u can use ur w/l connection rate me solved if its helps thx
Nov 04, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
57 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
