Question about Microwave Ovens
My microwave made a pop sound and then quit working. Nothing metal was put inside it. Do I need a repair person or can it be easily fixed?
  • 72 Answers
Most likely the hv capacitor shorted and blew the fuse, should fairly priced repair
Posted on Feb 04, 2010
GE Microwave oven is making popping sounds.
This is because the coating inside the oven or the wave guide has been damaged and microwaves are hitting bare metal and causing sparks. Take the light bulb out of it and when it is dark, put a glass of water in it and turn it on. If you can see the sparks then you know what needs to be repaired. You can buy microwave oven paint. It is special paint though, you cannot just use any paint. If you cannot see sparks then the area that is damaged is inside the unit and it should be taken in for repairs. If you don't fix it, it will blow out the magnetron and you will be looking at a new oven.
May 24, 2015 | GE Microwave Ovens
The plastic round ceiling cover in my OTR Samsung smh9187 has always been missing the locking clip/screw and has gotten loose but was easily turn back in position, yesterday it came loose and fell down ,...
Microwave ovens have special coatings on some of the interior panels and covers to prevent arcing. If there was arcing then that can cause the main component in the oven to fail and be expensive to replace. IF you do keep it you have find what is arcing and repair that.
Dec 27, 2014 | Microwave Ovens
Popping sound coming from my panasonic NNCD997S
The following works better if done in "low light".
Put a cup of water or small bowl in the unit, close the door and turn the microwave on.
If there is anything that you can see in the cooking area, there should be sparking and it is coming from something metal, even a small piece of aluminum foil that was left behind. The thing causing the sparking needs to be removed.
If you hear the noise and it is coming from inside the area of the microwave that you cannot see then you can:
1 - Take it to a repair shop.
2 - Depending upon the cost for repair, consider buying a replacement.
If the noise is inside the machine DO NOT CONTINUE TO USE IT. Get it FIXED OR REPLACED for your own safety.
Good Luck
Apr 06, 2013 | Panasonic NN-S969 Microwave Oven
I have a ge spacemaker microwave JVM1640sj03. It makes a popping noise as the table turns when I have food in it. What can I do to fix this and why is it happening. Many thanks.
theres something metal inside the microwave look for a screw or something that may have been placed in there during a repair. metal causes the microwaves to reflect back to the magnetron creating the popping noise you hear.
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Apr 26, 2009 | Whirlpool GH8155XJ Microwave Oven
Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Oct 03, 2008 | Whirlpool Microwave Ovens
ELECTRICAL POPING SOUNDS
Hi there - I assume you have a rack in the Microwave. What happens is the rack due to putting something in and out of the Microwave some times wears against the back wall of the cooking chamber. As this happens it wears through the paint and exposes the metal casework.
You then get microwave arcing between the metal rack in the microwave and the cooking compartment casing which gives that spitting popping sound. I would say get some white model paint and paint over the scorched spot (as long as its not gone so far as to wear a hole in the case work).
Wait for it to dry and stick the rack back in and try again to warm up a cup of coffee or something and see if it stops.
Also if you pull the grill slightly forward in the holders towards the door and test it you may notice that it doesn't pop as much so I would paint it and pull the grill forward and see if you still get the issue.
Best of luck.
Sep 04, 2008 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
