Question about Sony KDF-42WE655 Television
Can i change lamp light or should it be serviced
    Scholar:
  • 130 Answers
You can change the lamp yourself. Lamps are cheap if that's your problem. You need a Philips for a Sony TV. Discount-Merchant.com has them because they're an authorized dealer.
Posted on Feb 04, 2010
How does one change the clearance lights in the front
clearance, what is that?
this is a usa forum. and we have books cars for USA>
if usa,
the glove box guide tells you how to change all basic lamps.
(those related to safety, by name, but we dont have clearance lamps)
why not post a photo to said lamp so we can see it.
there are, up front.
head lamps high and low beam
parking lamps.
turns signals.
fog.
is this a match>?
check fuses yet.
are left and right side dead? or just one,
if one is dead, the lamp is bad.
in the USA the jeep is called WK.
and the full book is here, and covers all that and 10000 more things.
RTM? read the manual, and tell where it is unclear/?
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Sep 24, 2016 | 2006 Suzuki Grand Vitara
Dw60w cata dishwasher has power,turn it on power lamp does not light up, changed lamp still dont light up or work.
Ck to see if dishwasher service switch is in on position . Did the breaker trip. Do you have power to dishwasher ? Is the door lock working ?
Apr 23, 2014 | Cars & Trucks
I have an occasional problem with my Hasselblad PCP80 projector. Shortly after switching on the lamp will go out for no apparent reason, but all other controls on the projector work okay. The high...
From my PCP80 Service Manual:
FAULT: The projection lamp is lit for a short moment and then goes out. POSSIBLE CAUSE: 1.The rectifier and lamp change board are out of order. AND/OR: 2.Both triacs turn on. Both lamps are lighted until the automatic circuit breaker is released. MEASURES: 1. Change both boards. 2. Change the triac board.
See Also:
FAULT: The projection lamp does not light. POSSIBLE CAUSE: The automatic circuit breaker has released. MEASURE: Reset the circuit breaker. AND/OR: Fuse F102 has blown. MEASURE: Change the fuse. AND/OR: The rectifier and lamp change board are out of order. MEASURE: Change both boards. AND/OR: The triac board is out of order. MEASURE: Change the board.
Dec 21, 2010 | Hasselblad PCP 80 Slide Projector
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
Sometimes the TV's lamp will not go on with the first Power-On
When the set shuts off again count the number of times the led on the front flashes and the color of it. ait will flsh a number of times pause and then repeat. this is an error code and will help diagnose the problem.
Apr 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
How do I reset the lamp timer once the bulb will no longer light up? I found out this is my problem, but can't see the menu screen because the lamp won't light up until the timer is changed.
On some Projectors that I used to service, Holding the power button whilst plugging into power did a lamp timer reset. ( Of course check the lamp is fully seated and the lamp door is closed- ( microswitch)
Jan 04, 2010 | Office Equipment & Supplies
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
What does it mean when the lamp light is flashing red on my television
It is time to change the lamp. See your operating manual for instructions how to do it.
Sep 16, 2009 | Sony BRAVIA KDL-46V3000 Television
Lamp replacement
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
May 21, 2008 | Sharp XR-11XC Multimedia Projector
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-42WE655 Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
