Question about Compaq tc4400 Tablet PC
Micro sd card drive not working
Micro sd card not working
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
Feb 06, 2016 | Nextbook Tablets & eReaders
How do i put videos from download program to micro sd card
Windows Explorer and a SD Card Reader connected via USB or a SD Card reader in your computer where the old Floppy Drive would have gone.
micro sd card reader
Jan 09, 2016 | Tablets & eReaders
Where is a tutorial to learn how to load micro sd cards and flash drives for tablet use?
http://www.howtogeek.com/201980/how-to-mount-a-flash-drive-on-your-android-device/
Apr 01, 2015 | Coby Kyros MID8120-4G 8" 4 GB Tablet -...
How do I get my micro sd card to work on my MiTraveler tablet
You will have to add an app at the play store. There are many, one that I have used is called send to card. Remember to turn off your device before removing your sd card.
https://play.google.com/store/apps/details?id=ru.gelin.android.sendtosd
Mar 10, 2015 | Tivax Tablet MITRAVELER7D4
Which 32G micro sd card is compatible with the nobis nb09?
Whatever brand of card fits your budget will work.
Feb 11, 2015 | Tablets & eReaders
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
How do i move storage from a sd card to the harddrive
Most phones have a MICRO USB Cable plug, all you need is the cable and plug it into your Computer. You can also remove the Micro SD Card and slit it into a MICRO SD Reader and plug it into your Computer. BOTH of these methods works well for me. Having the proper cable is paramount in ensuring it has the ability of working the way you desire.
Oct 21, 2014 | Samsung Galaxy Tab Tablet PC
How do you transfer pictures to micro sd card on Zeki 7" tablet
well if youre device doesnt have a slot for the sd card, then you will need the right adaptor cord sync with another device
Sep 20, 2014 | Digital Products International Zeki 7
Insert micro sd card
It only fits into the slot one way. If it doesn't slide in smoothly, don't force it; try turning it around, or inserting it face down--one orientation will work.
Aug 11, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Mar 31, 2012 | Coby Kyros 716829701508 Tablet PC
Compaq tc4400 Tablet PC Logo
432 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
