Question about Dishwashers
Water not getting hot.
The dishwasher runs the program as usual but the water is not getting hot and pots are still dirty at the end.
    President:
  • 1,185 Answers
Heater gone?
Get someone with a meter to test it for continuity
Posted on Feb 04, 2010
Water is getting in to the dishwasher and its running the programme to the end.making usual noises but when open at the end the tablet is on the floor of the washer and pots not clean. Any ideas?
this usually indicates a faulty heating element or control board. Open it up half way through a cycle. if its cold then you know at least where to start.
May 04, 2011 | Neff 24 in. S5443X2 Built-in Dishwasher
Tablet not dissolving, and dishes dirty
Hi,Nicole, try this:
Run the water nearest the dishwasher (usually the sink), getting the water as hot as possible immediately before starting the dishwasher. This will help getting the tablet to dissolve.
--Best regards, --W/D--
Apr 05, 2011 | Bosch Dishwashers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
The washing cycle takes 2 hours to complete
Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
My tablet won't dissolve.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
May 16, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
