Question about Dell A940 All-In-One InkJet Printer
What is 0502 error mean? - Dell A940 All-In-One InkJet Printer
  • 4,041 Answers
050 Error 0502 and 0504
Hi there
You can try this
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
5 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Hardware Error 0502
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5150.
  3. Leave the power cable disconnected for 30 seconds.
  4. Reconnect the power cable and switch the printer on again.
  5. When the printer powers up, you will need to select the desired settings.
  6. If this does not resolve the problem
  7. You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.Its a transparent plastic strip ..Please be very careful with strip if its broken then printer will not work...
  2. Disconnect the power cable from the back of theprinter
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
  7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  8. Lightly press the strip first to the rear and then forward, if necessary.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer
  10. Try to make a copy..
Good luck....
Posted on Dec 04, 2008
Roop1980
  • 228 Answers
SOURCE: hardware error 0502 and error code 50c
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. Lexmark will replace the printer, only if it is under warranty.
Posted on Apr 26, 2009
SOURCE: what does error 0502 mean? I tried wiping off the
this should answer your problemhttp://www.fixya.com/support/t114419-error_0502
Posted on Jan 03, 2010
  • 257 Answers
SOURCE: What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Posted on Jan 21, 2011
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
What does the error 0502 mean when you are trying to make a copy.I am using the Lexmark X6170 All in One..
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error. This from Clem.
Dec 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
My Lexmark X 5150 keeps showing error 0502. What does this mean?
on a lexmark x 5150 error code means ink cart. We were out of ink.
Oct 02, 2009 | HP DeskJet 5150 InkJet Printer
Error Code???
The 0502 error can be caused by four different issues:
    1. A contaminated encoder strip
    2. An unseated encoder strip
    3. A faulty black/photo cartridge
    4. A faulty color cartridge
Your best look see at the problem would be www.lexmark.com >technical support> Model name >FAQs
May 04, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmarx X5150
see on this site. I had the same problem before 15 minutes and it helps :)
Feb 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark hardwear error code 0502
Open the printer. Take a Kleenex and wipe off the metal rail the cartridges travel on. You will find a lot of ink build-up. Be sure to wipr off the ENTIRE rail. You should be good to go!
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
