Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Wavy lines and jogging TV picture
My DVR-625 has been acting up for the last year, with wavy lines and a TV picture that jumps around. The picture on the separate TV in a bedroom upstairs is fine. When we play DVD's on the main TV, they are clear. When I called Dish Network a week ago, I spoke to someone in India, who kept saying "don't worry", and had us go through a scripted elementary procedure and then said there's nothing he could do. I called Dish again the next day, got an English-speaking rep, who had us go through the same procedure, unplug and plug in again etc., and said the problem was our TV. When we checked our previously recorded shows on the DVR, they had all been erased. I called Dish again, and told them about lost recordings and the hard drive problems, and they said there's nothing they could do.
The back of the DVR625 has ( cable out to separator (#123254) plus ch.21-89 cable to separator. This separator is then hooked up to a UHF/VHF reducer (Holland Electronics DPD2) which follows one RG6 coaxial cable to the wall.
What can I do to narrow this problem down to the cause? Is it the cables? Is it the DVR? Or, could it be (grrrr) the TV??? Any suggestions are most welcomed.
  • tbaz Dec 19, 2008
    I hvae the same problem. Initially I had it all connected through a receiver and though that was the issue. So I connected the video out directly to the TV using RCA, S Video, using each one of the Video IN, ports on the TV the same things happ[ened to all. I tried a coax cable to the antenna in and that was worst.
    The DVD player works fine and when I hook a video camera to the video in pot, using RCA kacks, it worrks fine. It is only the signal from the Dish unit directly to this TV.
    Dish did replace the unti with a new one for another issue and the new one did the same thing. The TV is a Samsung DLP.
    It seems that there is an interferane coming across the video line. I also tried hooking the video output from TV 2 to TV 1 and the same thing occured.
  • 51 Answers
It could be any of the things you listed, the coaxial output on the dvr, where it says channels 3-4 out, the cable , or the coaxial input port on your tv. the dvd player is probably hooked up with rca cables (red white and yellow) so the reason you dont have the issue with it is because its on a different port, one solution would be to hook your receiver up to the tv using this kind of cable, this would also get you stereo sound, you would then watch dish network programming on a video input channel,
if you want to narrow the problem down, i would suggest hooking a vcr up with the cable thats connected to 3-4 out, play a tape and see if the issue continues, if not the issue is with the dvr, if so try a different coax cable, if this resolves the issue, the issue was the cable, if not unfortunately the issue is your tv
Posted on Aug 07, 2008
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
Duo DVD 625 to HDMI
Hi my name is Mike Houston a Social Media Representative at DISH. With our Duo SD 625 DVR, it cannot receive HD signal, there will need to be an upgrade to our HD duo DVR systems. If you have any further questions about our DISH equipment please e-mail me at;
May 29, 2012 | DISH Network DVR-625 DTV Receiver /...
Can I connect the usb port on the DVR-625 to a TV with a usb connection and get a better picture? ?
Hi Roy Yoerger!
You would not be able to use the USB connection on your receiver to get a better picture. To get the best picture on our Standard Definition receivers, I would recommend using Component (RCA) cables.
Tommy Faust
DISH Social Media Representative
Feb 25, 2012 | DISH Network DVR-625 DTV Receiver /...
Have a dish 625 and hooked up new 1080p got a picture like a cartoon--fuzzy with blurry borders around images what so i do?
Hello, this is Matthew Gonzales with DISH Network customer service. A fuzzy/distorted picture can be caused by a couple different things. First of all, although your TV is 1080p HD, the 625 DVR is a standard definition receiver so the picture may not be as clear as expected. You should be getting a clear picture, but it will not be HD. First thing I would do is check the cables, making sure that any cables that you use are secured, and not damaged. If possible you may even want to try replacing cables. You can also try performing a reset on your receiver if you haven't. To reset your receiver, you simply unplug it from its power outlet for about 15 seconds, then plug it back in. Your receiver will reboot, which takes about 5 minutes. If you have performed all of these steps, or continue to have the issues, please email me at
Nov 29, 2010 | DISH Network DVR-625 DTV Receiver /...
DVR refuses to rewind or pause live TV or record
If you are still experiencing problems with your 625 receiver performing live DVR functions, try unplugging the receiver for about 10 seconds and plugging back in. This will cause the receiver to reboot and acquire satellite signal. After the picture returns, then try to pause. If it still doesn't work, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Jul 08, 2010 | DISH Network DVR-625 DTV Receiver /...
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
On screen caller id failure
common problem on 625 receiver. Have you hit menu 6-1-2 to enable caller id? If so call Dish and have them send you a new receiver out and give it a try. I'm sure it won't work every time, but it has to be better than what you have.
Apr 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Mar 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Lines on TV with DVR-625
try using a better cable from the receiver to the tv. sometimes less expensive cables dont "ground " as well as they should after a few years. the more shielding the better. the cable here will sell you the cable much cheaper then going to any store and its better quality, even if your not a customer of cable.
hope this helps
Mar 12, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
447 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
