Usb sometimes work as v1.1 instead v2.0 - Computers & Internet
  • 644 Answers
It all depends on whats plugged into the usb port, some need the v2.0 and other devices just use 1.0, so you will find that the usb port will change. If it changes randomly for the same device check the drivers in the device manager, it can be found in the my computer properties.
Posted on Feb 04, 2010
Iphone charging
Are you charging with usb? Sometimes it doesnt get enough pwer over usb so you may use the ac plug instead. If you experience that too, just leave it connected to the pc thru usb for sometime. Pls turn it off first. it could come up anyway.
May 02, 2013 | Apple iPhone 3G
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
The mouse will quite often stop working until I turn it off and back on, and sometimes the left click will get stuck. not the actual button, but the effect of it, if you understand what i mean. As of...
The MX 5500 is a usb bluetooth keyboard and mouse, I had this problem as well when I went beyond the range of the bluetooth. What i did to solve it was puchased a usb extension cable and moved the base key closer to my keyboard and mouse. (seems to me the limit was about 15-20 Feet.) and dont get any metal obstructions in between the receiver key and the kybrd / mouse such as a metal heat vent. ps. i do really like that unit, when it works it works well.
Aug 29, 2010 | Logitech MX 5500 Mouse
HP Deskjet 6940 Connection Issues
i am not sure of the steps which you have follwed till now,
just try performing the steps below..:
click on start
click on run
type msconfig and click on OK
click on start up tab
uncheck the HP related options from the list...
also check the option " hide all microsoft services"
apply ok..
if the issue persists, write back..
Narendra Tirunahari
Jan 22, 2010 | HP Deskjet 6940 InkJet Printer
My PC has a blue screen that reads VOLUME_MOUNTABLE_BOOT I followed instructions on blue screen to fix problem but of course it still doen't work any Ideas? Dell Dimensions 5150
Sometimes those kind of problems are related to usb devices (any kind of usb devices, even printers) try to disconnect any usb and test it.
If not try running the chkdsk command, you will need to boot using a windows installation cd and select repair instead of install after booting from cd.
Apr 17, 2009 | HP Pavilion dv2000t Notebook
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
MP3 will not charge
change usb cable or clean usb port and connector
Mar 06, 2008 | SanDisk Sansa e270 MP3 Player
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
