Question about Consew 226R-1
The book on my consew 226r-2 says to adjust the screw to tighten or loosen tension on the bobbin, I can't see a screw, where is it?
  • 32 Answers
It is usually a little tiny screw on what holds the bobbin in and where the thread passes through the bobbin. (The holder...not the metal or plastic bobbin spool of thread...it's sometimes called a shuttle to avoid confussion.) When you tighten or loosen the screw on the bobbin holder it puts more or less pressure on that metal hook the bobbin thread passes through.
Posted on Feb 04, 2010
I am sick of the peaple across the street ******* w/my sewing machine! I think a shot gun ill solve the problem.,,, : )
Posted on Dec 22, 2011
I have a consew 227 without reverse and can't tighten the bobin thread for the life of me. Do you think it might be out of timing? Please help thanks in advance.
THE SPRING THAT TIGHTENS AGAINST THE THREAD IS BENT OUTWARDS. IT MUST BE BENT INWARDS BY KEEPING THE TIP HELD UP WHILE YOU PUSH DOWN ON THE SPRING WITH A SMALL SCREWDRIVER. THIS WILL BEND THE METAL INWARDS. NOW, WHEN YOU TIGHTEN THE SPRING AGAINST THE THREAD IT SHOULD TIGHTEN AND LOOSEN AS YOU ADJUST IT. TO ADJUST YOU JUST NEED TO HANG THE BOBBIN FROM YOUR FINGER AND BOB IT UP AND DOWN. WHEN YOU ADJUST IT PROPERLY THE BOB WILL CAUSE THE THREAD TO EXTEND ONE INCH. THIS HAS NOTHING TO DO WITH TIMING SO DON'T BE CONCERNED ABOUT THIS.
Dec 27, 2014 | Consew Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
How do i set the bobbin tension
Small screw on side of bobbin case.
Apr 17, 2014 | Consew 226R-1
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Consew industial machine keeps skipping large areas
remove the front cover around the needle area also you may have to just strip the machine down!! to the hard ware with the bobbin door removed rotate by hand the crank till the neddle goes down to the bobbin area and losen the screws on the bell part of the crank and adjust it till
the needle is dead center and all the way into the bobbin then tighten and reassemble
Jan 14, 2010 | Consew 226R-1
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Thread breaks off
Where does it break? You change tension at the top via the tension discs the thread passed through, and at the bottom by adjusting the small screw on the bobbin case - the screw on the front part of the spring. Thread size matters as well as needle size. For everyday upholstery I use #69 nylon thread, and "G" bobbins.
If the thread's breaking at the hook you may need to adjust timing. But most commonly thread breaks because of improper tension, threading, needle or thread size.
Mar 22, 2009 | Consew 226R-1
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Consew 226R-1 Logo
487 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
