Question about LG 60PC1D 60 in. Plasma Television
I have a lg 42inch plasma tv we heared what sounded like a crack and the screen want blank but we still have sound
  • 131 Answers
This is caused by the main IC overheating on the Y SUSTAIN BOARD
This board when the back is of your tv is on the left hand side, You can confirm this as the board has 2 x white fuses on it. The fuse marked f2 will be blown, Replacing this DOES NOT correct the fault.
You need to order a new board as you can not buy the IC needed anywhere!! Beleive me iv tried!!!!!!!
Hope this helps to all theat have this model, This is also the same for the 42" & 50"
Posted on Mar 05, 2010
  • 111 Answers
Y-sus and possibly buffer boards
Posted on Feb 04, 2010
No picture, no sound
Diagnose the Problem
The first step in diagnosis is to check the display for any cracks on the screen. If the screen appears cracked, then the repairs may require plasma screen replacement. A cracked screen means that the gases inside have probably escaped. There is no way to refill the gases and the whole display will have to be changed. In this case, an authorized service may be able to provide more details. If the problem persists, then a gas leak is perhaps not the cause of a loss in display. Lamp burnout could be one reason behind a blank screen.
Check the Fuse
Most of the time, the plasma TV fuse is at fault for no picture on an LG Plasma screen. In such a case, changing the fuse should make an LG Plasma TV functional.
  1. Unplug the TV and wait for 10 minutes for the capacitors to discharge.
  2. Take a Digital Multimeter and set it to the 0-200 ohm range.
  3. Touch the red and black probes to each other and check the readings. The multimeter reading should be in the range of 0-2 ohms.
  4. Now touch the red and black probes to each end of the fuse. If the multi-meter reads '1' or 'OL', then the fuse has blown and needs replacement. If the multi-meter shows the same reading as before, the problem lies elsewhere. Some cases may require the motherboard to be completely replaced.
Fix the Problem
If an LG plasma TV has no picture and no sound, then either the Y-sustain or the Z-sustain are at fault. Follow these steps to determine and fix the problem.
  1. Unplug the TV and wait for 10 minutes for all the capacitors to discharge. Then open the back panel of the TV.
  2. Unplug the Z-sustain from the TV and plug the TV into the power supply. If there is sound, then the Z-sustain is faulty and will need changing.
  3. If there is no sound, follow the same procedure and unplug the Y-sustain. Check for sound. If there is a sound, then the Y-sustain is faulty.
  4. If the Y-sustain is faulty, a user may have to check the Y-buffer. He will have to follow the same procedure and unplug the Y-buffer this time. If there is some picture with sound, it means that the Y-buffer is faulty.
Keep in mind that a plasma TV runs on very high voltage. The voltage on some connectors exceeds 400V (in excess of 200 joules of energy). This high voltage can be very dangerous. That why it's important for users to always make sure the capacitors have discharged before performing any type of diagnosis or fixes on an LG Plasma or any other television set.
Feb 04, 2016 | LG 42PW350 42-Inch 3D Plasma HDTV...
My 42 samsung plasma tv lost picture
hello i have a 42inch plazma pdp42v6 check all caps ok
all board ok sound ok but no picture can anyone help me
fix this problem please
Dec 21, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
I get the letters msg on the bottom of my 42inch lg plasma why is this
Menu, Special, Software update....2 choices Manual and auto
Put on manual and you start getting MSG at the bottom of the screen.
Put on auto and it stops.
Andy
May 20, 2010 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Lost picture on plasma tv
Check the power board for any domed capacitors. Replace them. If this does not fix Replace the power board. You can check the voltages from the power board. they are labeled. VS and VA voltages are the panel voltages.
Mar 25, 2010 | Televison & Video
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have a LG Plasma 42" TV and the screen doesnt come on.
Could be the XL/XR scan circuits, or a problem on the sustain board.
How old is your tv?
Mar 01, 2009 | LG 42PX4DR 42 in. Plasma TV
How you cann repair a broken plasma tv with out replacement parts
The tv plays fine my sreen is cracked on my Sony 42inch screen can some one help me.
May 13, 2008 | Samsung HCL4715W 47" Rear Projection...
LG Plasma 50PC5D Help
sounds like the internal screen has cracked look closeley to see if you can see any cracks if so new screen im affraid if no cracks suspect power board
Mar 20, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Feb 23, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
LG 60PC1D 60 in. Plasma Television Logo
283 people viewed this question
Computer Repairing
Computer Repairing
