Question about Jabra BT135 Bluetooth Headset
BT135 blue tooth discovery mode ?? - Jabra BT135 Bluetooth Headset
    President:
  • 1,738 Answers
Here's the link for the user guide:
http://bit.ly/bW8Kyw
It will tell you how to set it for discovery mode. And, remember to bookmark the page.
It's in PDF Format so it may take a minute for the page to load. If you need a PDF Reader to view it you can download Adobe Reader for free:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Posted on Feb 04, 2010
Cant connect bluethoot
If you are trying to hook up a blue tooth ear piece. You have to put the ear piece into discovery mode. See the instructions that came with the ear piece for how to do that. Then put your phone in discovery mode so they find each other. Then you will have to know a pass key and enter that into your phone. Most blue tooth pass keys are 0000 or 1111 or 1234. hope this helps FixYa up.
Aug 28, 2011 | Cell Phones
Need to know how to pair lost pairing info
first you have to turn the power to blue tooth on ,then you will have to put ur speaker into discovery mode,most blue tooth manufactures use the power button for this feature by holding it down for 6 to 10 seconds when turning on the device it will put it into discovery mode,your phone or computer or game system should be able to recognize the blue tooth device then.It will ask you for a pin pairing code,now most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 hope this helps
Feb 26, 2011 | Blueant Sonic Bluetooth Portable Speakers...
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
It is not being detected by my new nokia C7
you must make sure you have your blue tooth device turn on to discovery mode most blue tooth devices you just hold the power button for 6 to 10 second when turning on the device,once it is in discovery mode your phone should find it,then you will need a 4 digit pn or pairng code,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra Radio Communications
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Setting the discovery mode
The user manual is here http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Press the button for at least 3 secs to getinto discovery mode Pairing and connecting Please note: You can only enter pairing mode from off position. Bluetooth® device must be in discoverable mode. Light Indicator flashes blue and red
Apr 15, 2010 | Plantronics Explorer 320 Wireless Headset
Jabra BT135 Bluetooth Headset Logo
515 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
