Question about Homelite Mighty Lite Lawn Trimmer
Im having troble starting when i try to prime no
Im having troble starting when i try to prime no gas is coming in to bulb. then if i take off the hose gas sprays all over the place . when it did run it would stall out a lot
Check out the valve to the bulb
Posted on Feb 05, 2010
My leaf blower will not prime there is no gas coming in the primer bulb
check to see if your gas filter is stuck inside the gas tank... it should sit loose at the end of the fuel pick- tube
Sep 14, 2014 | Garden
Help, need to start a briggs and stratton 158 mower, and can't. not mine, so not sure of its quirks, also not a lawnmower person, use a brushcutter normally. lawnmower in good condition, got oil and...
after trying to start it a bunch of times, take spark plug out and see if it's wet with gas.
All mowers start with throttle High and with the choke on OR if it has a primer bulb, you have to prime it until you see gas in the bulb
Aug 28, 2013 | Briggs & Stratton Garden
I have an mcCulloch 325bp back pack blower gas wont come to in the primer bulb
Try replacing the fuel filter in the tank, if this is bloced it will not fill the bulb
Jun 16, 2012 | McCulloch Carburetor 322410-01 Blower 280...
Will not start. I prime the unit by depressing the bulb 7 times, the choke is full and the throttle is full. It simple does not try to start.
take the spark plug out pull the rope and see if gass comes out of thr cylinder which tell you theres to much gas coming out if your getting to much gas pinch your fuel line pull till it starts thenunpinch it if its firing it will start
Nov 05, 2009 | Garden
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Engine starts when I hand prime it,but not when I use prime bulb.
There are two screws on the carb. 1 is Lo rpm air/fuel ratio and the other is hi rpm. Try adjusting the lo rpm screw counter-clockwize a 1/2 turn at first, more if needed. After each adjustment try to start. The other thing you could check is if the float is sticking in the bottom of the carb. which shuts off gas flow if full. There is a screw on the bottom of the carb to drain that float. You can try that also! Good luck man!
Sep 21, 2009 | Craftsman 25cc Gas Line Trimmer
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
133 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
