Question about Maytag PAV2300 Top Load Washer
My maytag Performer Heavy Duty Washer will not stop filling with water. Is there a sensor control or fuse or something I can do myself? help
Yes there is a sensor for water level. If you open the top lid of the washer (The entire top of the washer), use a small flat-head screwdriver inserted in the middle of the front metal panel where it meets the top metal panel (use a flashlight to see the clip inside. Push in on the black metal retainer clip and simultaneously pull up slightly on the top metal panel to lift it up. The top panel (which includes the top access door) will hinge at the back of the washer frame and will allow for full access to all internal parts associated with water level sensor at the tub itself. There is a small plastic nipple that comes up from the rear left (as standing in front of the washer like when you wash clothes) of the outer tub. This nipple should have a small clear rubber tube on it secured with a small spring hose clamp (use a pair of needle nose pliers to squeeze the clamp to get it off or on). The hose runs up to the back of the control panel (the part on top that has all the dials in it. To open the control panel to see if the hose is connected to the sensor, gently lower the top panel of the washer again and look at the very top of the control panel and remove the three screws that hold the face plate on and then tip it back (towards center of the top of washer) on its face and check to se if the other end of the hose is connected to the back of the water level sensor. The tube is clear so you can see if there is any wear (a hole) or a clog in the hose. Either of these problems will stop the pressure to get to the sensor and make it so that the washer will not know that the level is where it should be. IF the hose is worn, cracked, clogged, or was a hole in it, you will want to replace it with a new one. You can save a lot of money by just going to a local hardware store and get something that is fairly close to it will work fine. Should only be a few dollars. Also, check to see if you can look into the plastic baffle plate in the outer tube and see if it is plugged which will also cause the same result in blockage. Lastly if all that checks out then the problem is with the sensor itself which requires a replacement of it from an appliance parts center near you.
Posted on Feb 07, 2010
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Washing Machines
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
Washer fills with water, but before it begins to
drain hose is siphoning. pull most of it out of the drain and secure with tie strap.
Jan 18, 2010 | Maytag PAV2300 Top Load Washer
I have a maytag heavy duty stack washer dryer. tonight The washer stopped working. The elctronic panel seems to be working and the water filled but the machine would not aggitate, spin etc.. it did show a...
Possibly the timer needs to be replaced, if a few of the teeth on the disc get broken off, it will not turn, and that causes it to NOT go into the next cycle. Happened to me, thank God for warranties
Jul 31, 2009 | Maytag Bravos MTW6600T Top Load Washer
Kenmore heavy duty 80 series won't stop filling with water.
I removed the top of my washer to access the switch. I had to pull some screws out on the back and pulled the whole top forward and then up.
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
