Amount of energy for 50 inch tv - Televison & Video
  • 8,457 Answers
Put on energy saving setting 1/3 energy consume less,but tv little slow to response in light intensity,and channels output.
Posted on Feb 04, 2010
Am thinking of buying the 55in digihome tv can you please advise the width and depth of the stand
The stand is pictured here. It is narrower than the television, so has no 'width' to worry about. The legs look to be about 12" front to back.
Digihome 55304UHDSM 55 inch LCD 1080 pixels 50 Hz TV Energy Class
Jul 17, 2017 | Televison & Video
I have an LG TV 50PV450 Plasma TV, and after a storm last night, it won't power on, however,standby light remains lit, solid.
Look for blown capacitors on the power supply board. They will have domed tops instead of flat tops Some will look puffy too. You can get a repair kit if you're handy with a soldering iron or replace the entire board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 25, 2016 | LG 50PV450 50 Class Plasma TV, 600Hz Sub...
How much power does a
Since 2011 the FTC has required that every TV display a yellow and black Energy Guide label estimating how much it costs to run for a year. The label assumes a price for electricity (11 cents/kWh) and a baseline usage (5 hours per day).
The cost is tiny. A typical label can read anywhere from $6 for 32-inch LEDs to $38 for 65-inch plasmas (PDF). Per year. That's from 50 cents to $3.18 per month.
Aug 15, 2014 | Televison & Video
Panasonic tv has a cracked screen
you probably better off buying a new tv cuz the amount you will pay will equal the amount of a new tv and plus that screen has like a million LED lights that the costly part but thats not why but the most costly part in the tv is the screen.
Mar 28, 2013 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
How much caffeine is in an energy drink?
The amount of caffeine varies greatly from brand to brand. For instance, a 250ml energy drink can have anywhere from 50-160mg of caffeine. The amount should be clearly posted on the side of the can and I would highly recommend checking how much caffeine is inside before consumption.
Feb 07, 2013 | Wine & Spirits
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
