Question about Panasonic KX-T7633 Corded Phone
Message light won't turn off
No new messages in mailbox. Message light stays on. Pressing message button and clear under LCD doesn't fix.
Thoughts?
Lift handset and dial star 790
Posted on Feb 23, 2008
  • rickkirkman Jan 13, 2011
    This was great! Solved an annoying problem quickly. Thanks so much!
I have listened to all my messages but my handset still blinks and says new voice mail. How do I access those voice mails?
Do it from the Base Unit rather than the handset.
Still doing it?
Remove plug from base unit overnight and the batteries from the handset to reset it.
Nov 29, 2016 | Lands Phones
Hi, the incoming message red light is staying on. However all new incoming messages have been cleared. How do I fix this ?? Thank you DOnna
2 ways to clear this (most likely someone tried to intercom you and pressed the message button on accident instead of hanging up):
way #1:
1) press the "MESSAGE" button
2) on the screen it will display who turned on your message light
3) press the "CLEAR" button (third button from the left directly under the screen)
way #2:
1) press "INTERCOM"
2) dial " *700 " then your extension number (you will hear a confirmation tone)
3) hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
My red message indicator light is on, but i dont have any messages. How do i fix this? Panasonic KX-DT343
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Carl
Jul 29, 2010 | Panasonic KXDT343 Phone
Message waiting indicator light is on but there are no messages
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
Aug 20, 2009 | Nortel Business Series Terminal T7208 -...
Message waiting led stays on even though there are no messages in voice mailbox
Good Luck.
Jul 14, 2009 | Nortel Business Series Terminal T7208 -...
My LG VX6100 won't accept voice messages
Problem solved! Turns out that my son didn't realize that you have to call your voicemail box and delete voice messages by pressing "7" on the keypad. He thought that when you pressed "erase all" on the text message menu it erased voice mail, too. So the mailbox was full, as it only holds twenty messages. Sometimes the most obvious solution is the solution!
Jan 12, 2009 | LG VX6100 Cell Phone
Phone answering machine
Moving a Message to Another Mailbox
You can move a message from one mailbox to another. The message is saved a a new message in the mailbox to which it's been added and is deleted from the original mailbox.
1 While the message you want to move is playing press "setup". The system beeps and stops playback, the Message Window displays CP (for copy) and the Mailbox lights flash.
2 Press the MBox button where you want to move the message. The system resumes playing messages in the original mailbox.
Aug 10, 2008 | AT&T 1726 Digital Answering Machine
Message lights blinks when phone rings but doesn't stay lite when store messages are waiting.
Store Messages are probably not recorded in the mailbox that is associated with the phone. Instead, they are probably in the General Delivery Mailbox or a mailbox associated with an ICD group.
Making it possible for the GDM to turn on a message waiting lamp is something that needs to be done when the system is first installed. Changing it later requires the entire voice mail system to be cleared, unfortunately. It is one of those things we always do for our customers, but most dealers do not.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
May 14, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633. Phone message box is busy
This, my friends, is a very popular problem. It is caused by someone else in your company pressing the Message button on their phone while you are calling them or they are calling you. We strongly recommend to our customers that no one presses the Message button under any circumstances. To access your voice mailbox, always dial the Automated Attendant access code assigned by your installer - usually 165 (although on our systems it is "62" or the letters "MB" for MailBox).
You need to dial the Message Waiting Lamp feature code and dial "0" for the extension number. The code itself varies from system installation to system installation, but the most likely numbers are *70 and 70.
Jan 14, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
1,524 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
