Question about Freezers
The temperature gradually heads towards the + side from an intial -18. It is not overpacked with food and has to be switched off for 24 hours and restarted before the temperature drops again Why?
  • 4,793 Answers
Poss cause machine is in auto defrost mode.check food still at minus 18c or lower.also when was the last time you defrosted/cleaned filters and drain pipes manually?
Posted on Feb 11, 2010
How do I reduce the freezer temperature
Locate the the thermostat - usually located in the fresh food compartment (if a refrigerator). Make small adjustments of about 1/8 of the dial's travel at a time - and check the change after 24 hours. Be sure to check both the freezer AND fresh food compartment to prevent temperature from dropping to low for fresh food. Best results are obtained by using a thermometer put in a glass of water in the fresh food area and another thermometer left in the freezer. Most manufacturers suggest a freezer temperature not greater than 0°F and fresh food 35°F to 40°F. If you need specific help with this - please include the make AND complete model number of your freezer.
Oct 23, 2015 | Freezers
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
Sep 07, 2014 | Electrolux Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
