Question about Dynex Voice-Certified PC Desktop Microphone
My microphone is plugged in but it wont let me record only hear what im saying through my computer speakers???
  • 414 Answers
You have to have a audio recorder viia your computer software. Try NCH or Audicity both of which are freeware programs
Posted on Feb 26, 2010
When Im done recording and replay it, there are parts that have glitches and repeat itself. What do I do? I checked everything and everything seems to be ok. Im not sure how I can fix it.
Do you mean you're hearing reverb (echo) of recording? If your recording music or vocals make sure playback speakers are off when doing so. If you leave them on, you're recording multiple times IE: ECHO
Mar 07, 2011 | Blue Microphones Snowball Professional...
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 21, 2011 | Audio Players & Recorders
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
When i skype with my granddaughter, i can hear her, but she cant hear me
It must be with your mic or with your computer's sound settings or with your skype sound settings. First check your Microphone, you can record something using the Windows (if your o.s. is windows xp or vista, or etc..etc..) built-in Sound Recorder.
Open your computer's sound settings and make sure it's default recording device is Microphone and the volume is turned up.
Open the skype, click "Tools", then "Options" and again click" "Audio Settings" and check the mic volume, if possible uncheck the "Automatically adjust the microphone settings" and turn the slider to the right. Save the changes you've made and try again.
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Skype IM
My contacts cannot hear me. Also message comes up and says microphone is very quiet and contacts may not hear
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure mic to chat program
Jun 18, 2010 | Creative Labs Live! Cam Video IM Pro...
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
My DYNEX microphone wont work
Perhaps you have it connected to the speaker connection? Have you looked at the microphone to ensure there isn't possibly a mute button you have accidentally pressed?
Out of curiosity, how are the others hearing you ask if they can hear you? If you are using the microphone to ask, perhaps they are just yanking your chain?
Jan 24, 2009 | Dynex Earclip Headset with Noise-Canceling...
Sound problem
ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Aug 04, 2008 | M-Audio Producer USB Microphone with...
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
Jan 12, 2008 | Toshiba Satellite A105-S4334 Notebook
Was working at first but now sound is too quiet
check mic level on recording mixer for windows N.B. r-mixer different from playback-mixer
Apr 05, 2007 | Sony FV100 Consumer Microphone
Dynex Voice-Certified PC Desktop Microphone Logo
396 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electric Dime
Electric Dime
Michel Laprise Sr
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
