Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
Vauxhall combo epic 1.7 Y(01) battery light
I have a vauxhall combo Y(01), It would run for 3 days and then die, I got the battery and the alternator checked. Ended up getting a new alternator, after three days died again. Realised the battery light wasn't lighting up when ignition was turned so replaced the bulb and everything was fine. Untill roughly two weeks, They said oil from the vac pumps must have got in and killed the alternator, which was replaced free of charge under guarantee. Now two weeks i have driven down from doncaster to derbyshire popped into tesco, started van up and battery light came on eventually went out after alot of flashing. This is the same way it went last time when the garage said it was oil from the vac pumps. Surely there must be another reason for this reacurrance?? Any ideas.
Update-
No charge relay seems to be on this van even though vauxhall says so, today we have found a yellow relay which is clicking when the battery light goes on and off in the process of replacing it. Any other ideas??
  • 3 Answers
The yellow relay is a red herring,its the glow plug relay just clicking as the current is trying to find another path to earth,id say its a dodgy regulator on alternator, but possible the light goe through the time circuit of the relan start up but id suspect regulator,
Posted on Feb 09, 2010
2006 VAUXHALL Astra Rev counter & battery playing up
remove the belt so the alternator does not work and run engine and see if the revs are normal. if they are the alternator regulator has gone or the diode board in the alternator. if still the same the dashboard controller has a problem.
Feb 21, 2018 | Vauxhall Cars & Trucks
Battery dies every few days - rebuilt alternator
Check your fusible links by the positive battery cable.Here's a link to it.
Nov 26, 2013 | Nissan Maxima Cars & Trucks
Battery light on followed by other lights then died
check the wire from alternator to the battery and make sure its not loose on alternator. happened to me a few years ago, forgot to tighten wire to alternator. car lights on dash came on and car quit while driving. just make sure you are getting at least 14 volts at battery while its running, good-day !
Oct 26, 2011 | 2006 Dodge Grand Caravan
My 1988 mx6 mazda car starting dying out plus battery light was on...I got a new battery. It ran tor two days, than it died out on me AGAIN! NOW it won't start.unless I get a jump, it runs for maybe 20...
Hi
If you have a new battery and it dies it means that the alternator is bad. The alternator is what replentishes the battery and run the car while you drive it. A simple test is as follows start the car, while the motor is running discinnect the (red) positive cable from the battery. The motor should continue to run....If it shuts off it means that the alternator is bad. The battery is only used to start the car! After its started it runs off of the alternator which also constantaly recharges your battery. Have any questions email me at jackdouglass@comcast.net
Sep 15, 2010 | 1988 Mazda MX-6
Battery light came on. same day while driving, it started to lose power. gas pedal wasn't giving power pulled over then died. wouldn't turn over replaced battery. next day took it for a drive was coming...
you alternator is no good to ceck alternator start car while running take off positive cable if it dies your alternator is no good but thats what it sounds like
Aug 20, 2010 | 2001 Volkswagen Jetta TDI
I boost the battery, and it does hold a charge but only for a day or a day and a half at most. I'm not sure what could be causing this problem. The battery was purchased Last year brand new, but sat all...
if the battery holds the charge for a day or 2 wile you drive the car normally then you should check your alternator live the car 2 or 3 days after the battery was charged and check if it starts and run if it does run it another 2 or 3 days and see if the battery dies if it dies most likely your alternator is bad, your mechanic can test it with in 3 minutes to see if it is the alternator or the battery
Aug 05, 2010 | 1991 Plymouth Sundance
I want to change front brake pads on a vauxhall combo epic 775 1.7d.I am not very mechanically orientated. Please ignore the product as vauxhall was not in the drop down menu.
If you are not mechanically minded you should not be attempting to change brake parts. If you really want to do the job yourself then get a workshop manual and study it before doing anything. Best of luck!
Mar 14, 2010 | 1986 Renault Sport
My vauxhall combo battery light keeps coming on and drains battery after few days. tried a new battery and same happened. fizzing sound near fuse box. Any idea what the problem might be?
I might have a similar problem, I brought the van 2001 combo 1.7. Put a new battery on earths have been checked new alternator, still killed the battery, Realised the battery light wasn't coming on when turning ignition, changed the bulb and was fine for about a month then the battery light started flashing. I have a relay (yellow) near the bonnet release which is clicking. I would strongly suggest checking the output of the alternator before considering replacing. www.willstar@gmail.com is my email address if you manage to figure your problem out please let me know as it might help me from pulling my hair out.
Jan 27, 2010 | Enlight Combo (5601908) (Beige) (5601908)...
BATTERY DIES OUT IN 2-3 DAYS.
are you saying that you got this battery from autozone? I went thru three batteries in a week from autozone because the lot# was bad. It,'s quite possible that you have either a short that is draining the battery or that the alternator isnt charging properly. To do a fast check, start the car then remove the positive battery cable with the car running. If it stays running, theres a chance its ok. If it dies, It's most likely the alternator or the voltage regulator Diods. On most cars, the voltage regulator is built into the alternator. I would take it to autozone and have the charging system checked
Jun 03, 2009 | 2006 Pontiac G6
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
1,201 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Larry Maranto
Jerry Umali
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
