Question about Canon i850 InkJet Photo Printer
Paper won't feed in my i850
When I select PRINT, the printer sounds like it should feed but doesn't.
Many thanks.
  • CygnusStella Feb 10, 2009
    Turns out that a small dark earring had fallen into the printer preventing the paper from catching in the rollers but not getting jammed itself.
    Thanks for your response, though.
  • David Fremont Feb 20, 2009
    Canon i850 will not load paper. I think the back support is supposed to swing forward but it doesn't move. DF
  • 1,602 Answers
CHANGE TO DIFFERENT PAPER PRODUCT
CLEAN THE ROLLERS
GO ON LINE TO
CANON 850i WILL NOT PICK UP PAPER
AND FIND OTHERS WITH THE SAME PROBLEMS
ROD
Posted on Feb 04, 2009
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
Canon ip3600: New Printer doesn t recognize that
Possible solution:
In Preferences/Properties, make sure that "Automatically Select" is selected in "Paper Source"
Mar 31, 2009 | Canon PIXMA iP3600 Photo Printer
Canon i850 receives message that there is a paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 22, 2009 | Canon i850 InkJet Photo Printer
Printer will not print!
You have a problem with the inner PMX motor inside your printer.
Call HP support
Nov 17, 2008 | HP DeskJet F380 All-In-One Printer
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
127 people viewed this question
old marine
old marine
