Question about Panasonic NN-T694SF Microwave Oven
It shut itself off after 7 min. Microwave....
I assumed it over heated but the microwave after 2 days now hasn't turned on. I was searching the forums and stuff, my thoughts are it could be the fuse but i need to go get a TX set.
any thoughts would be good...
Thanks in advanced....
Funny story to add, so i brought up our old microwave and it just recently blew up (the bulb or whatever) soo now i have 2 broken microwaves....
    Sergeant:
  • 260 Answers
Sounds like an overheating, probably burnt fuse, maybe due to a bad fuse holder. or for that matter just a blown fuse for a variety of reasons. Will have to check fuse or see where it is losing power
Posted on Aug 16, 2017
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Posted on Oct 14, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave shutsdown after 24 seconds, does not heat up
Classic symptom of a defective inverter. It it's under warranty, you're probably in luck. If not, expect repair costs of about $120-150. If you can find a servider who will repair the inverter instead of just replacing it, you can save some money. If you or a friend can replace it yourself, you'll really save, assuming you follow safe procedures. You can find my file "safety.txt" via a Yahoo search. It is part # A606Y5X00AP for model NN-T993S and runs $62.83 plus shipping. The inverter can be gotten from Panasonic at http://www.pasc.panasonic.com/epartr
Posted on Nov 01, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave 1200
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Sep 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: keeps blowing fuses
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Posted on Nov 09, 2008
SOURCE: Panasonic Microwave about 9 years old with
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Jan 28, 2010
Testimonial: "Couldn't ask for more - response was prompt, helpful and clear. Thanks "
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Overheat turn off
After a quick internet search I found that Samsung has had problems with thier microwaves turning on by them self. I would unplug it till you need to use it and contact samsung or local repair shop about getting it fixed
Mar 14, 2014 | Samsung Microwave Ovens
I select High/Med/Low, set time say 1 - 2 mins microwave starts up light comes on, fan comes on, table turns...but after 20-30secs table stops, light goes off, disply reverts to clock time, fan runs for...
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type. In this case it seems that the program controller board has errors specially if the oven heats and shuts off. remove the board, clean and reset.
If there is heating without any issues, you can use the microwave safely
May 16, 2011 | Microwave Ovens
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Sanyo EM-G2585W 800 Watts Microwave Oven
It's possible that the unit is overheating, and shutting itself down to make sure that it doesn't melt or burn. Do you have it against a wall, or in a cabinet where the unit cannot vent? Is there a fan? Is it working? --j.
Jun 19, 2007 | Sanyo EM-G2585W Microwave Oven
Sep 01, 2006 | Panasonic NN-T993SF Microwave Oven
Panasonic NN-T694SF Microwave Oven Logo
104 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
