Question about Air Tools & Compressors
I bought a Harbor Freight 34 degree Nail Gun, model 93099. I shot about two clips of nails, but now when I press the trigger, I get a blast of air. I removed the safety trigger and (carefully) pushed in the trigger button, same thing, juat a blast of air. I called Harbor freight and they said to disconnect and reconnect the air, which I did, and to add oil to the air inlet, which I did...nothing different. Help!!!!!!!!!! Thank you in advance for your help. Richard
    New Friend:
  • 109 Answers
If its oiled, then take all the nails out of the track and chamber, check to see if your firing valve is stuck( it is suppose to go up and down , opening and closeing the cylinder, but sometimes it gets stuck) first press the safety in all the way ( you may have to pull the feeder down ) then press the trigger , then hook the hose to the gun in that order this will sometimes unstick the firing valve
Posted on Feb 16, 2010
How do I find a manual for central pneumatic 2-in-1 18 guage brad nailer/stapler kit 2 item 97524/40116?
Unfortunately, harbor freight retires nail gun models very often. They only list the current nail gun models on their web site, thus manuals and parts are only available for a short time. The only help is that the new models are similar to the old. Sometimes the internal parts are the same but at least the user instructions should be the same. Download various manuals from similar models on their web site today and compare. Do not order parts unless you are sure about fit. As far as orings, you can use generic also from harbor freight (oring kits in standard and metric, not expensive).
Good luck
Feb 15, 2015 | Air Tools & Compressors
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Can you use regular round head nails in the cliped nail version ?.
Your gun uses 30 -34 degree clip head paper tape. Order a sample of the nail below. It may work on your gun. These are offset full round head with paper tape. Safe way to test if nails will work is to remove the head of the gun and insert nails into rails. Push down on the driver with wood handle of hammer to eject nail. This will test for jamming or two nails trying to eject and cause jam. Look down barrel to see if the head is alighed correctly or too far from centerline of driver.
http://www.mazenails.com/catalog/catalog.php?page=PAGE04&group=PT34
Aug 24, 2011 | Porter Cable Cable No. FC350A Clipped Head...
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
I have a 34 degree Campbell Hausfeld framing gun and after connecting it to the air compressor and with 125 lbs. air pressure I click the trigger and it doesn't fire.
May just be a stuck headvalve or safety is not pushing trigger pin all the way into trigger valve. If trigger pin is being pushed up all the way into valve, check headvalve. Remove head and try to press in headvalve with thumbs. If it feels stuck, apply air pressure to vent hole on gasket surface to pop it out. Apply silicone paste lube to surface and orings. Re-install and check. If head valve was not stock, lube and replace head.
Feb 01, 2011 | Campbell Hausfeld Round Head Framing...
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Two nails at a time and one of them only goes in one quarter of an inch.
Campbell hausfeld makes a 21 and 34 degree angle nail gun. The most common mistake is the wrong nails are being used. Some after market nails will not work correctly in some guns. Check to see if the gun accepts wire welded or paper clip nails. Check the angle required. Also be sure the gun is oiled if it is not an oil- less gun. hope this helps.
Jan 11, 2010 | Campbell Hausfeld Air Tools & Compressors
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
What brands of nails will work in my 15ga finish nailer 1000993
Here are a few tips on buying nails for your nailer. Nails are sold in two basic categories, clip head and full round head. The clip head are lower in price and are usually taped on glued together with no spacing between them. The full round head have spacing between each nail and are held together with plastic. Some nailguns can use both types. It is important to verify the angle of your gun. To measure the exact angle use a straitedge along length of rails and a protractor at the barrel of the gun. Place the protractor on the barrel with the 90 and 0 degrees aligned with the barrel and hold the straitedge aligned with the rails and the 0 degree mark. Read the angle. You may find that your gun measures a different angle. Nails are sold from 0 to 34 degree. 34 degree is usually clip head for Paslode, Senco, Hitachi and other brands. I find that many brands of nails do not list the angle, but list the name of the gun instead. This makes it difficult for non-branded guns. Take the protractor into the store and measure the angle of the nails or place the nails on the outside of the rails to see if they align with the barrel. Shop several stores because nails vary by brand. Once you verify the perfect fit, ask for a sample strip to try in your gun. When you identify the angle and type, use this information to shop for price. Most nails are imported from around the world, however there are nails still produced in the US costing more. Home Depot and Lowes do not carry a full range of nails.
=Google the internet for more info on nails such as www.nailzone.com. They sell a 33 degree nail that may fit your gun. Good luck and email me or post again with more questions.
w
Jan 19, 2009 | Northern Industrial Tools Air Tools &...
Air Tools & Compressors Logo
432 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
