Question about Toshiba Satellite A300-0CF035 Notebook
I have a Toshiba satellite pro A300 which when it is powered up shows the 1st screen with options for setup etc using F2 and F12. The laptop responds to neither and goes to blank black screen with a white cursor in the left top corner. What can I do to see if there is any life in this machine?
  • a_brown_1 Feb 04, 2010
    Thanks but it is not getting to the F8 stage of booting to try this
  • 316 Answers
Hello,this is a common problem that is caused regularly from a virus or a software/driver that you have recently added and caused this.The first you must do is to try to boot from safe mode(pressing F5,F8) while you booting and enter safe mode and remove anything you installed recently.Also you can try to select Last Know Good Configuration.If non of this helped you must reinstall or repair the operating system.Am waiting for your reply.Good luck
Posted on Feb 04, 2010
  • marios basileiou
    marios basileiou Feb 04, 2010
    Have you try to repair the OS?
Not shown booting options
f8 or f9 shows the booting option
Aug 08, 2013 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite L355D-S7815 had windows 8, opened up laptop and cleaned all the dust out and now when i turn the laptop on it shows the Toshiba screen but no F2 or F12 option's.
What you are talking about is called no POST. You either shocked the cmos and the bios wont load or something is not hooked up right.
Mar 21, 2013 | Computers & Internet
When starting it appears normall gives F2 and f12 option after that the screen becomes black
Was the laptop on? Projector on?
If so this = No.
Toshiba Satellite C600 specifications,
http://egadgetsclub.com/laptops/toshiba-satellite-c600-notebook-review-specifications/
Intel Pentium Dual Core T4500,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#NetBurst_based_Pentiums_2
Go to F2 option. That should be - enter BIOS Setup.
Look at the main menu (Which it automatically goes to)
Or use Down Arrow to highlight Standard BIOS options, and press Enter key.
Is the Harddrive listed? HDD0 has harddrive info listed to the right?
(HarDDrive0)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Computers & Internet
How do I enter setup when there is no option to enter
F2 is your bios setup, and F12 is the boot order selection, if you cannot access the two options there is no other way. That shows up when the Toshiba logo is visable. If your windows run properly I would not risk formatting the hard drive. But it might be worth contacting Toshiba, customer and technical support about the unusuall situation.
Mar 14, 2012 | Toshiba Satellite A55-S106 PC Notebook
My toshiba satellite l455 won't start up it keeps going 2 toshiba home screen and telling me 2 push f2 or f12
click on F2 and that will take you to the Bios setup, check that your hard drive and Ram (Memory) are both online if all is ok and no problems press F12 it might take you to a diagnostic screen prompting you to perform a diagnostic test, if so do the tests and write down any errors given, if there is not diagnostic tool you might get the options to restor factory defaults this option will reset your computer to its original state and you will lose all your data. Another option if you have the operating system's cd (windows xp, vista etc) from the bios (F2) change the boot sequence to cd (just click on Cd/DVD Rom)only and reboot, windows will ask you if you want to repair, if all your hardware is ok and you should be able to solve the problem good luck and all the best
Jun 06, 2011 | Toshiba Satellite L455S5000 Notebook
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba Satellite A300-0CF035 Notebook Logo
584 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
