Question about IBM Infoprint 1222 Laser Printer
How do you set the ip address on an IBM 1222 - IBM Infoprint 1222 Laser Printer
    Sniper:
  • 126 Answers
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
Posted on Aug 18, 2010
    Problem Solver:
  • 18 Answers
Tricky one. Sorry you will not like this answer: Per IBM quick setup guide
If your network is using DHCP, an IP address is automatically
assigned after you connect the network cable to the printer.
1 Look for the address under the “TCP/IP” heading on the
network setup page you printed in “Printing setup pages” on
page 24.
2 Go to “Verifying the IP settings” and begin with step 2.
If your network is not using DHCP, then you must manually assign an
IP address to the printer.
An easy way to do this is to use the Print Server TCP/IP Setup Utility.
Detailed instructions about installing and using this utility are located
on the drivers CD that shipped with your printer. Launch the CD, click
View Documentation and then Network Printer Install. Look for
information about using the Print Server TCP/IP Setup Utility.
To use this utility, you will need to know the printer’s 12-digit physical
address or Universally Administered Address (UAA). Look for the
UAA entry on the network setup page you printed earlier. You can use
either the MSB or canonical form of the UAA.
You will need to locate or replace your original cd to get the utility.
Posted on Apr 05, 2010
3 Suggested Answers
Muggs01
  • 72 Answers
SOURCE: Just moved IBM 6400 dot matrix. Need new IP address.
it should have kept the same address
Posted on Jan 19, 2009
SOURCE: I need to add IBM
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 20, 2010
Are there any drivers for the ibm infoprint 1222 for windows 8?
for now, i don't think its available.but wait some time and it may come out:)
Nov 27, 2012 | IBM Infoprint 1222 Laser Printer
Where i can find drivers for IBM infoprint 1222 for Vista?
Good afternoon i_prodanov,
you' ll be able to "download the drivers for the IBM Infoprint 1222,"
at this 'website', that I "linked you to.
Select the "Drivers you need from the list."
Click on the 'link' below.
"I hope you find what you need! Rating the help, is always appreciated"
Click here: http://www.ibm.com/search/csa/search?sn=spe&filter=+ibmtaskid:DL#q%253dIBM%2520infoprint%25201222%2526filter%253d%252bibmtaskid%253aDL%2526sn%253dspe%2526sortby%253d-moddate%2526o%253d0
Mar 18, 2011 | IBM Infoprint 1222 Laser Printer
I need to add IBM Infoprint 1116 to my home network using IP address. How can I change already setted IP and gatway addresses on it to needed?
May 20, 2010 | IBM Infoprint 1116 Laser Printer
Driver for infoprint 1222 printer when using window vista
Download it here:
1. If you have 32-bit operating system: ftp://ftp.software.ibm.com/printers/drivers/ip-universal/vista_x86/printer_ud0_vista_x86_pcl_emul_sys_en.exe
2. If you have 64-bit operating system: ftp://ftp.software.ibm.com/printers/drivers/ip-universal/vista_x64/printer_ud0_vista_x64_pcl_emul_sys_en.exe
Feb 15, 2010 | IBM Infoprint 1222 Laser Printer
Need drivers for vista 64 bit OS
Download drivers from:
http://www-01.ibm.com/support/docview.wss?uid=psd1P4000605
Feb 06, 2010 | IBM Infoprint 1222 Laser Printer
I have an ibm r40. cannot connect to my wireless router.was working perfectly prior. when i hard wire to the wireless router the ststus show an ip address of 0.0.0.0
if you can set up your connection manually change the IP adress to 192.168.1.1 (this is usually the default IP adress for most routers) let me know if this helps I have more Ideas for you if it doesnt
Nov 15, 2009 | IBM ThinkPad R40 2681
How do you change the IP address on an IBM 6400 printer
The IP address is usually assigned by your router using DHCP. I assume you are trying to print to the printer from your PC and it won't go. Go into your router using IE and look for the IP address assigned to the printer and write it down. Exit IE.
Next, go into Control Panel>Printers and choose the IBM printer. Go to Properties and choose Configure Port. Enter the correct IP address, hit apply and exit. You should be able to print to the IBM now.
Sep 02, 2009 | IBM 6400 Matrix Printer
Is $80 (CAD) a good price for used IBM 1222 printer w/ 50% toner
It's a good price, you mainly look a rubber rollers for age or wear, listen for quiet smooth printing, if you can look at the fuser rollers in the exit, look for wear and toner sticking. Print quality issues may show need for a toner cartridge.
Aug 11, 2009 | IBM Infoprint 1222 Laser Printer
Home router won't exchange IP to set up wireless on laptop??
try resetting the router to factory settings, it may have been set to allow only 2 or 3 wireless connections, just take a pen and hold it in the reset hole on the back of the router till all the lights blink and it restarts
Dec 10, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Infoprint 1222 Laser Printer Logo
1,026 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
