Question about Sharp EL-2630P Calculator
Time/Date How do i set the time and date on the Sharp EL - 1801v 12digit Calculator?
How do i get the date and time to print?
Posted on Jun 07, 2008
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the displayTime/Date - 1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Mar 12, 2008
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
How do I set the date and time on my EL-1801V calculator?
Push the button at the top over from GT to SET.
type the date in using the decimal as a spacer.
Then press the date/time key.
for the time...
Press the date/time key until the date shows,
then enter the time in military time and press the date/time key again.
Dec 01, 2008 | Sharp EL-2630P Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Date & time
See the instructions under "NON-ADD / SUBTOTAL KEY" in the third column of the first page of this manual: http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1801V.pdf
Aug 11, 2008 | Sharp EL-1801P Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
Sharp EL-2630P Calculator Logo
839 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
