Question about Brother HL-4040CN Laser Printer
I have a Brother HC-4040CN. When pulling the new stuff out of the machine, I accidentally removed the rear fuser cover. Now, I cannot get it back on. Can you please assist me with this?
  • 3 more comments
  • avrcd Feb 04, 2010
    Thanks, but I don't want to pay more money for an answer. Anyone have a FREE answer?
  • avrcd Feb 05, 2010
    I have the user's manual here as well, and it doesn't show how to install the fuser cover.
    Neither of those are helpful at all. I don't understand why I keep getting things sent to me that aren't helpful. Is this what I'm paying for? This problem is in the BACK of the printer... not the front.
  • avrcd Feb 08, 2010
    THat does not show how to put on a fuser cover when it's come completely off. I need to know how to install it when it's come off.
  • avrcd Feb 23, 2010
    Okay.... I figured out with my copier repair guy. We took the entire fuser out, with a screwdriver, and then put it on the fuser when it was out. It went right in!
    President:
  • 3,278 Answers
Hello.
Although this does not show when the cover is completely off ... this hopefully will give you a good idea ...
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000300/000009/faq000309_003.html?reg=us&prod=hl4040cn_all&c=us_ot&lang=en
Posted on Feb 09, 2010
  • 596 Answers
I would like to assist you with your printer issue today. If you don't mind, could you be more specific about what happened when you pulled "the new stuff" out of the printer. (What is the new stuff and when did you notice the problem?)
Thanks
C2Solutions
Posted on Feb 05, 2010
  • 542 Answers
Find the below url to download the user's guide for your printer. Please go through it and try to fix the problem.
http://www.manualnguide.com/manual-get/11915/
Revert back for more assistance.
Posted on Feb 04, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please download the Service Reference Manual, Parts List, and Service Manual from the bellow side to fix the rear fuser cover of your printer
http://www.service-docs.com/store/catalogue.php?cat=128&exp=&resultpage=3
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Check whether the balance load sensor is faulty or not or check pump/filter for blockage
How do you change the fuser unit
printer back cover remove & then 4 screw remove the fuser unit ,remove the printer side cover and disconnect the fuser connecter & pull the fuser unit slowly
Jul 03, 2014 | Brother MFC9320CW All-In-One Printer
Paper jam in rear
Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
Feb 19, 2014 | Brother MFC Office Equipment & Supplies
Hi, we just used iron on paper in the printer, and the paper got stuck. we think it melted to the rolls on the back of the printer, the oragane and black rollers. what do we do????
Oops...You need to remove the fuser unit from the printer & attempt to carefully remove the melted paper. You can use a sharp object to get started but be very careful not to damage the surface of the heat roller. This needs to be a slow patient job but it should come off.
Otherwise you will need a new fuser unit.
May 26, 2011 | Brother HL-4040CN Laser Printer
How do I install a fuser unit on my brother mfc-9440CN?
l.- Take the back cover off
2.- Remove two screws
3.- Remove one connector
4.- Pull the fuser unit out
5.- Replace with a new one .
Feb 14, 2011 | Brother MFC-9440CN Laser Printer
How do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Mar 25, 2010 | Brother HL-4040CN Laser Printer
#10 envolopes crimple when printing.
Open the back cover. Where the green handles are, there are gray handles attached to these. Move those all the way down, that is the envelope setting. I did not know this until I ordered a new fuser, the new one has labels on it!
Sep 11, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
Re-attach fuser cover on Brother HL-4040cn
I had the exact problem. Had to order a new fuser unit, as this is not a serviceable part. But I took pictures for future reference. CLICK HERE.
Service Manual I found online for free download
Sep 20, 2008 | Office Equipment & Supplies
I have a Brother HL-4040CN. It says there is a rear paper jam. I opened the back, cleared the paper and reclosed. The error message won't clear. I have taken all the removable pieces, front and back...
Probably when you remove the paper, some sensor was placed out of order (by the sheet pull) , or is with any malfunction. You have to check them. Are at least 3 sensors (1- presence of paper on the tray, -2 paper entrance, - 3 paper passed in the fuser).
May 02, 2008 | Office Equipment & Supplies
Brother HL-4040CN Laser Printer Logo
172 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
