Question about Nokia N95 Cellular Phone
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
  • Nokia Master
  • 2,517 Answers
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Posted on Feb 04, 2010
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My L6 will not come on or charge up
i had that experience before. i was not able to charge my motorola l6, then i went to a cellphone repair shop then i ask the technician to shock my battery. and then it went up and get charged!
Mar 13, 2009 | Motorola Mobility L6 Cellular Phone
Won't charge or turn on
maybe the problem was your battery, i just think that youve overcharged it. try to replace another battery. hope that helps!
CHARCOIS
dont forget to rate my post thanks!
Jul 27, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Charging problem
check the base connection this can be damaged if the charger is inserted the wrong way.
If this has happened then you will need a tech to repair it.
If it is not this then I think your battery has died
Nov 16, 2007 | Samsung SGH-E370 Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
New Nokia 2660 phone battery dead
does the battery bar go up and down like it is charging or is nothing happening if nothing happening then it is probably your charger has packed up it might be a split wire inside the cable try another charger or take it to a phone shop and they will try it for you for free and they can tell you if its your charger hte battery or the phone if the phone hasnt got wet then it probably is the charger u can get these cheap and a phone shop might have some second hand ones this should solve your problem hope this is some help
Oct 28, 2007 | Lands Phones
Won't Charge
if it went threw the washer its garbage dude.. sorry haha
Oct 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Nokia N95 Cellular Phone Logo
150 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
