Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
I got 2 pcs of kicker 12L7, one is 2ohm and the other is 4ohm DVC. in there any chance i can run them together with one amplifier? i got a venom VD2600S and venom 1600.D, will it be ok if i use each power to run each subwoofer? and would it be better to use VD2600S or 1600.D to push the 2ohm or 4ohm L7? thanks in advance
    Sergeant:
  • 212 Answers
Run the amp in stero Run the 2ohm to one chanel, Wire the dvc 4ohm to run 2ohm + to + - to - to the other chanel and you should be fine.
If you had a 1ohm stable amp you could run both speakers wired 2ohm to a mono amp and have a 1ohm set up and double the power!
Posted on Feb 05, 2010
Hi. I have 2 kicker rt 2ohm dvc subs. And 1 4ohm svc. Can i hook them up to a kicker cx 1200.1 amp. Pls help. Thnk u
Not if you want it to sound good. All speakers should match so equal sound comes out of each.
More info here - http://sparky3489.webs.com
Jan 23, 2015 | Kicker Car Audio & Video
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
I have 3 10" clarion
If your sub woofers are DVC 4OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.67OHM load or if connected Series/Parallel then you would have a 2.67OHM load. If your sub woofers are DVC 2OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.36OHM load or if connected Seies/Parallel then you would have a 1.67OHM load and Series/Series a 12OHM load. So if your sub woofers are really DVC, it would be impossible that your amp would be playing 4OHM. The numbers just don't add up. There are amplifiers out there that can deal with 0.50OHM loads but expect them to be on the pricey side, but fairly so, because mostly higher end brands tend to manufacture them and are usually pretty good. Remove 1 of the sub woofers. If i knew what the subs where 4 or 2 OHM DVC and what amplifier you are using i would tell you how to connect them for the best possible result. hope this helps dreamsystems
Feb 07, 2011 | Car Audio & Video
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
What car amp to use to run 2 dvc subs
You need a stereo amp that can run 400amps
continous, with an output of 4 ohms. These should
not be too hard to find and they are getting smaller
all of the time. Make a practice look on ebay.
They give you pictures and you can check the dimentions first, so you know it can fit between
your two deck lids.
Apr 25, 2009 | Kicker CVR8-4 Car Subwoofer
I have 2 kicker cvr 4ohm dvc hooked to a pheonix gold rival amp
If the amp is not kicking what it should it probably s a wattage problem. Check to see if the alternator has high enough voltage distribution. That is also why it keep shuting down.
Feb 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
373 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
